But it does help block higher frequencies before reaching the woofer voice coil where the power would be wasted.The circuit is very simple so it will sound bad and it might damage your speakers.
The inductor in series with the woofer speaker is useless because the woofer is already an inductor. You need to add a capacitor parallel with the woofer speaker to make a lowpass filter.
The capacitor in series with the tweeter is so simple that it cuts low frequencies gradually then the tweeter will be damaged by midrange and low frequencies.
Most woofers produce a "shriek" sound at about 4kHz due to a resonance and cone "breakup". A single inductor in series barely reduces this bad sound.
You do not want a series resonant LC feeding a mid-range speaker.
Tweeters are fragile and can be damaged if only a single series capacitor cuts low frequencies.
Here is from the datasheet of a typical cheap American 15" woofer:
I plan to use this Crossover Network design for my power amplifier with an output of 100W. Is this design good enough.
Hi again, Nigel.I suggest you try listening to commercial speaker designs (particularly cheap ones), rather than reading datasheets - which are pretty meaningless.
But regardless, stick a 15" or 8" speaker in a box, play music through it (no crossover of any kind) and it will neither 'shriek' nor 'honk'![]()
Hi E-Tech,
Your midrange has a sharp shrieking peak in the response at 8kHz. It will be very noticeable to anybody with normal hearing.
I could not find a Dayton DC-60FA midrange speaker but their DC-50FA does not have that peak. Maybe the peak is caused by the crossover network feeding the inductive high impedance of the midrange speaker. Then a Zobel Network parallel with the midrange speaker will reduce its impedance at 8kHz to 8 ohms so that the crossover network can work properly. Does the crossover calculator assume that the speakers have Zobel Networks installed?
The crossover frequency between the midrange and tweeter is very high at about 9kHz. Maybe it should be reduced to about 4kHz?
Likewise, the midrange response shows its honking resonance at 400Hz where it might destroy itself. Then maybe the crossover frequency between the woofer and midrange should be increased to 800Hz?
This midrange speaker is causing problems at both ends of its response, maybe it should be removed and use a two-way crossover instead?
I like the response of the little 8" woofer giving excellent output at 20Hz. I do not like the tweeter having too much output.
Lastly, the crossovers are 2nd-order. Then when the speakers are in-phase like you show then they form a notch at each crossover frequency instead of adding.
eTech,
Where did you get "tweeter.lib"?
Please attach you spice and lib files. I would like to give it a go.
You can plot V(tweeter)+V(mid)+V(wolf) to get the total frequency response.
Ron,
----edited----
I don't know the frequency response of the raw speakers so we really don't know the total frequency response of the system.
Here is the frequency response of a Dayton 385-8. There is a nasty bump at 1.2khz. Hopefully the cross over network will role that off.
The frequency response below 200hz will depend greatly on the enclosure.
AND
Here is the impedance of this speaker. I don't know if the SPICE model takes into account the inductive effect above 200hz.
You know more than I do.I've added the Zobel Network componets to each speaker model and attached a new simulation.
