Chicago357
Hello -- My daughter is doing an invention fair project in which she aims to create a simple analog device that can magnetically attach to the exterior of a dishwasher and that will contain a light indicating when the dishwasher has been run. This light will go on when the surface temperature of the dishwasher reaches a minimum temperature and then must remain on until it is manually reset (eg, whenever someone comes along to empty the dishwasher).
She has found a small surface mount disc thermostat that closes on rise (normally open) at 85 fahrenheit (https://www.alliedelec.com/product/selco/ca-85/70098628/) that seems like it would provide a good temperature sensor. The only problem is that it has auto-reset, meaning it will re-open once the temperature drops back to normal again. She can't find anything equivalent to this that has manual reset. Of course, if she uses an auto-reset switch, then the light will go off as soon as the temperature of the dishwasher drops back down, which basically makes her gadget pointless.
Is there a way to set up the circuit in such a way that would allow the light to stay on (with manual reset) even after the temperature drops (and the temperature-sensing switch goes back to open)? Is this where a "relay" would come in?
Thank you for any help or suggestions you can provide!
