Cordless phone system
ELauria
Can an extension antenna be added to a 2.4 Gig phone system so that I can use an extension in my cellar?
cordless phone
And what if there is no external antenna Jack? How can I attach one and maintain the proper impedance?
Re: cordless phone
You have BIG problems!.
The high frequencies make it far more difficult, way back down at 145MHz you adjust aerials by cutting off a few mm at a time - at 2.4GHz you would need to be trimming small fractions of a mm for the same effect.
This supposes you have the required test equipment to do so at these frequencies?.
2.4 Gig Phone System
I have another base station with an antenna that should be the right size. What cable should I run to the cellar to connect the antenna and how do I connect to the existing antenna up stairs and would the connection change the impedance of the system?
Re: 2.4 Gig Phone System
You use coaxial cable suitable for the frequency in use, and of the correct impedance for the aerial and phone. Usually the impedance is 50 ohms.
As to how to connect it, presumably the aerial has either a coaxial cable coming out of it, or a socket to plug a cable in?.
