Hi all,
I want to connect my computer to my radio transceiver (transmitter/receiver). This means connecting the line-out from the sound card to the mic port on the radio, and one of the lines in a serial cable to the PTT (push to talk). (Connecting the received audio to the PC is done separately.) I could buy a commercial solution, but a) that would cost £40+, which is downright daylight robbery for what it is, and b) that's boring.
The aim is to connect it to the mic port (which appears to be an RJ25 connection). This is the actual mic (schematic).
Now, I'm pretty much a complete novice at electronics. I did some at school a few years ago, but that's about it, so please bear with me.
From what I can tell, this circuit should work to switch the transmitter on and off. Obviously it's completely useless for any practical purpose (transmit what?), but I'm going to do this first just so I can get to grips with things and see that it works. Does it look correct?
From here there are two things to do: 1) activate the PTT from a serial cable, and 2) connect the mic to the line-out on the PC. For the PTT this means checking the RTS line. If it's on, close the PTT circuit, otherwise leave it broken. I would guess the check would be done with a transistor, but would the two circuits need to be separate? I'm not really sure what to do here.
As for the mic, I don't even know where to start. In the schematic the mic is in the top left with a bunch of capacitors and other bits and pieces, the purposes for which I don't know, or if they're even relevant. I would need to connect a 3.5mm jack in place of the mic.
Any advice would be greatly appreciated.
Chris.
Chris.
