clockspeed 18f4520
Goos_E
I try to program a oic 18f4520, but i get stuck on the clocksetting (I think).
what happens when i program the chip it goes to the first setting of PORTD and then it stops.
I think it has something to do with the clocksettings or the configuration bits.
I tried it with waitms and with a loop both don't work.
Thanks in advanced,
Goos.
Define CONFIG1L = 0x00
Define CONFIG1H = 0x89
Define CONFIG2L = 0x1a
Define CONFIG2H = 0x00
Define CONFIG3L = 0x00
Define CONFIG3H = 0x83
Define CONFIG4L = 0xc0
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
TRISD = 0
main:
PORTD = 0
WaitMs 250
PORTD = 255
WaitMs 250
Goto main
This is my code.
I tried to switch over the portD 0 to portd 255 and all it does is execute the first portd assignment. That is al leds burning or no leds burning. ( i have swiched both portd commands)
Right..... Oshonsoft's simulator will take a day to do a "waitms 250"
At the top of your code insert...
DEFINE SIMULATION_WAITMS_VALUE = 1
Then the code will stop for a much shorter time When you use a REAL device you change it to..
DEFINE SIMULATION_WAITMS_VALUE = 0
I am using a real device. I think i am doing something wrong with the clocksettings or something in that direction. I am using no crystal and using the internal oscilator. If i delete the waitms in the code i got a somewhat darker leds. So i think that the code is running,
I think i have found the problem. When I disable the /mclr pin selection to /mclr_off_3h the program works just fine.
You should have the MCLR pin tied to V+ through a 10k resistor when you're not using that pin. If you just leave it floating, the chip might mistake the fluctuation for a reset signal. It would help to see the schematic you are using.
Regards,
Matt
I haven't used a schematic yet. I am just expirementing. I would sure use a 10k resistor now. Is that the problem with mclr pin. I don't know.
If you're not following a basic ICSP schematic then no wonder it's not working! PICs tend to be very picky (no pun intended) about how they're connected. You really should read a datasheet and do some research before experimenting with microcontrollers. Otherwise you risk damaging them (and no, I'm not being over-dramatic here, I'm 100% serious).
But yes, chances are the reason it's not working is because you don't have MCLR tied to V+ with a resistor.
