clocks
dave_1986
i am currently doing an AS-level electronics project and my project includes a clock, i have made a working 555 astable clock but i need to experiment with other types of clock. So can anyone suggest any other ways of making clocks to me?
+ needs to run at 250Hz +/- 30Hz
There are many different kinds of oscillators, you could try two transistors as an astable multivibrator, a schmitt trigger gate with feedback around it, opamp oscillators - the list is pretty well endless.
You could even use a micro-controller to do it, an 8 pin PIC would be a lot more accurate than a 555 (I had to get a PIC in here somewhere!).
Crystal oscillators
How do you set them up in a circuit and how do i use on to give a short positive pulse every second?
Re: Crystal oscillators
Presuming you mean PIC's, there are many different ways to do it. You could use an internal hardware timer to generate interrupts, and count the interrupts. But a simple way would be used nested loops to waste time, so if you wrote a subroutine to delay 1000mS you could do something like this.
Start:
Make output pin high
Make output pin low
Delay one second
Goto Start
That would only take a few lines of PIC code, the biggest part would be the delay routine (and that wouldn't take much). By carefully altering the delay routine you could get a pretty accurate clock pulse - with a 4MHz PIC you can trim the routine to within 1uS.
As it stands, it would produce a very short pulse, to lengthen it simply add another delay routine between the high and low lines - remembering to shorten the main delay by the same amount.
