Clock
Damn interrupts:
This is the configs for the interrup. Im trying to set INT1 & INT2 where :
INT1 = Low Priority
INT2 = HIGH Priority
/*  Interrupt Items  */
    RCON = 0x80;
    INTCON = 0xC0;
    INTCON2 = 0x80;
    INTCON3 = 0x98;
            Interrupt Code
#pragma code low_vector=0x18
void interrupt_at_low_vector(void)
  _asm GOTO low_isr _endasm
#pragma code /* return to the default code section */
#pragma interruptlow low_isr
void low_isr (void)
    myTmp = PORTB;
    UpdateTime();
    INTCON3 = 0xFC;
#pragma code high_vector=0x08
void interrupt_at_high_vector(void)
  _asm GOTO high_isr _endasm
#pragma interrupt high_isr
void high_isr (void)
    myTmp = PORTB;
    alarmOut = 1;
    RTCRegRead(0x07);
    INTCON3 = 0xFC;
Any thoughts of why this isnt working? It seems to only jump to the "high_isr".
I have the 1hz thing from DS1306 to RB1 and RB2 is the INT0 from DS1306
ok this code is all of it except set the date i left the simplest for last lol The interrupt seems to be working now i think i had a bit wrong dont remember.
 *          AtomSoft Clock Using PIC18F248, DS1306, 74LS164, 74LS165
 * FileName:        main.c
 * Author:          Jason Lopez
 * Processor:       PIC18F248(0)
 * Compiler:        C18
 * Company:         AtomSoftTech
 * Version:         1.0.0
#include <p18F248.h>
#include <stdio.h>
#include <delays.h>
#include <spi.h>
#pragma config WDT = OFF, LVP = OFF, OSC = HS
Prototypes
void main(void);
void initSPI(void);
void e_togg(void);
void lcd_line(char line);
void lcd_cmd(unsigned char letter);
void lcd_char(unsigned char letter);
void lcd_string(char *senpoint);
void lcd_init(void);
void delay_ms(int mS);
void delay_us(int uS);
void delay_s(int S);
void lcdByte(unsigned char dNyb,unsigned char rs);
char RTCRegRead(char adx);
void RTCRegWrite(char adx, char data);
static unsigned char uint2bcd(unsigned char ival);
char readBtn(void);
unsigned char bcd2dec(unsigned char aBCD, char type);
void putDate(char type, char data);
void UpdateTime(void) ;
void ShowMenu(void);
void SetTime(char type);
void low_isr(void);
void high_isr(void);
Definitions
#define CS LATCbits.LATC2
#define CS_T  TRISCbits.TRISC2
#define SCL_T TRISCbits.TRISC3
#define SDA_T TRISCbits.TRISC4
#define SDO_T TRISCbits.TRISC5
#define LCD_DAT_T TRISCbits.TRISC0
#define LCD_CLK_T TRISCbits.TRISC1
#define LCD_DAT LATCbits.LATC0
#define LCD_CLK LATCbits.LATC1
#define LCD_E_T TRISCbits.TRISC6
#define LCD_E   LATCbits.LATC6
#define PL  LATBbits.LATB0
#define CP2 LATBbits.LATB1
#define SDL  PORTBbits.RB2
#define PL_T   TRISBbits.TRISB0
#define CP2_T  TRISBbits.TRISB1
#define SDL_T  TRISBbits.TRISB2
#define Button      (PORTA >> 1) & 0x0F;
#define Button_T    TRISA
#define setupBtn    0x01
#define downBtn     0x02
#define upBtn       0x04
#define selectBtn   0x08
#define alarmOut  LATBbits.LATB3
#define alarmOutT TRISBbits.TRISB3
#define alarmIn_T   TRISBbits.TRISB1
#define OneHz_T   TRISBbits.TRISB0
Variables
char string[]       = "                ";
char string2[]      = "                ";
char company[]      = "  AtomSoftTech  ";
char SetStr[]       = "    Settings    ";
char SetTA[]        = " Adjust:        ";
char TimeStr[]      = "1. Set Time     ";
char DateStr[]      = "2. Set Date     ";
char AlarmStr[]     = "3. Set Alarm    ";
unsigned char lDate[16];
unsigned char myTmp;
/*       NEW VARs       */
unsigned char decHour;
unsigned char decMin;
unsigned char decAPM;
unsigned char BcdHour;
unsigned char BcdMin;
unsigned char BcdAPM;
unsigned char BcdSec;
unsigned char decDate;
unsigned char decMonth;
unsigned char decYear;
unsigned char time[16];
unsigned char comDate[16];
unsigned char view;
Main
void main(void) {
    ADCON1 = 0x0E;
    initSPI();
	lcd_init();
    SDL_T = 1;
    Button_T = 0xFF;    //TRISA (all input)
    RTCRegWrite(0x8F,0x05);
    alarmIn_T = 1;
    OneHz_T = 1;
    alarmOutT = 0;
    alarmOut = 0;
    RCON = 0x80;
    INTCON = 0xC0;
    INTCON2 = 0x80;
    INTCON3 = 0x98;
    UpdateTime();
    view = 0;
    RTCRegRead(0x07);
    while(1) {
        myTmp = Button;
        if(myTmp == selectBtn){
            if(view == 1){
	            lcd_string(company);
                view = 0;
            } else {
	            lcd_string(comDate);
                view = 1;
            UpdateTime();
            while(myTmp == selectBtn){myTmp = Button};
        if(myTmp == setupBtn){
            INTCON = 0x00;
            ShowMenu();
            UpdateTime();
            delay_s(1);
            INTCON = 0xC0;
        if(myTmp == upBtn){
            alarmOut = 0;
RTC Tools
Convert Char(byte) to BCD
	return ((ival / 10) << 4) | (ival % 10);
Convert BCD to Char(byte)
    char lowNyb = aBCD & 0x0F;
    char highNyb = aBCD >> 4;
    char MyDec = lowNyb;
    char x;
    switch(type){
        case 0:
            highNyb &= 0x0F;
            break;
        case 1:
            highNyb &= 0x01;
            break;
        case 2:
            highNyb &= 0x03;
            break;
        case 3:
            highNyb &= 0x07;
            break;
        case 4:
            highNyb &= 0x00;
            break;
    for(x=0;x<highNyb;x++){
        MyDec += 10;
    return MyDec;
Read a Register off the DS1306
char RTCRegRead(char adx){
    char tmp;
    CS = 1;
        WriteSPI(adx); //sec
        tmp = ReadSPI();
    CS = 0;
    return tmp;
Write to a Register on the DS1306
void RTCRegWrite(char adx, char data){
    CS = 1;
        WriteSPI((adx | 0x80 ));
        WriteSPI(data);
    CS = 0;
Initialize SPI
void initSPI(void){
    CS_T = 0;       //CS is output
    SCL_T = 0;      //SCL is output
    SDA_T = 1;      //SDA is input
    SDO_T = 0;      //SDO is output
    OpenSPI(SPI_FOSC_4,MODE_10,SMPEND);
    CS = 1;
        WriteSPI(0x8F);
        WriteSPI(0x00);
    CS = 0;
LCD Functions
Send String to LCD
void lcd_string(char *senpoint){
    delay_ms(1);
	while(*senpoint != '\0'){
		lcd_char(*senpoint);
		senpoint++;
Send Data(Nybble) to LCD
void lcdByte(unsigned char dNyb,unsigned char rs){
	int i;
	LCD_DAT=0;							//Clear 74LS164 set initial bit to 0
	for(i=0;i<8;i++){				    //repeat for 8 bits
		LCD_CLK=1;LCD_CLK=0;			//write 0's to the 164
	for(i=0;i<4;i++){				    //output the nybble
		if((dNyb & 0x08) != 0)
			LCD_DAT=1;
		else
			LCD_DAT=0;
		dNyb=dNyb<<1;
	LCD_DAT = rs;						    //output the RS bit value
	LCD_DAT = 0;
	e_togg();
Toggle E Line
void e_togg(void){
	LCD_E=1;LCD_E=0;
Set LCD Line
void lcd_line(char line){
    if(line == 0x01)
        lcd_cmd(0x80);
    else
	    lcd_cmd(0xc0);
LCD Send Command
void lcd_cmd(unsigned char letter){
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,0);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,0);
LCD Send Character
void lcd_char(unsigned char letter){
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,1);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,1);
LCD Initialization
void lcd_init(void){
    LCD_E_T = 0;
    LCD_CLK_T = 0;
    LCD_DAT_T = 0;
	lcdByte(0x03,0);
	delay_ms(5);
	e_togg();
	delay_us(160);
	e_togg();
	delay_us(160);
	lcdByte(0x02,0);
	delay_us(160);
	lcd_cmd(0x28);					//set 4-bit mode and 2 lines
	delay_us(160);
	lcd_cmd(0x10);					//cursor move & shift left
	delay_us(160);
	lcd_cmd(0x06);					//entry mode = increment
	delay_us(160);
	lcd_cmd(0x0d);					//display on - cursor blink on
	delay_us(160);
	lcd_cmd(0x01);					//clear display
	delay_ms(500);
Delays (S,mS,uS) for 20Mhz
    Delay Second(s)
void delay_s(int S){
    int y;
    char x;
    for(y=0;y<S;y++)
        for(x=0;x<4;x++)
            delay_ms(250);
    Delay MilliSecond(s)
void delay_ms(int mS){
    int y;
    for(y=0;y<mS;y++)
        Delay1KTCYx(5);
    Delay MicroSeconds
Lowercase 'u' is common
symbol for Micro
void delay_us(int uS){
    int y;
    char x;
    for(y=0;y<uS;y++)
        for(x=0;x<5;x++)
            Nop();
readBtn
char readBtn(void){
    char tmpA;
    tmpA = myTmp = Button;
    while(myTmp == tmpA){myTmp = Button};
    return tmpA;
LCD / RTC stuff
void UpdateTime(void) {
    unsigned char tmp,tmp2;
    char i;
    // Fill In the LCD String
    time[0] = 'T';
    time[1] = 'i';
    time[2] = 'm';
    time[3] = 'e';
    time[4] = ':';
    time[5] = ' ';
    time[8] = ':';
    time[11] = ' ';
    time[13] = 'M';
    time[14] = ' ';
    time[15] = ' ';
    // Get Date
    comDate[0] = 'D';
    comDate[1] = 'a';
    comDate[2] = 't';
    comDate[3] = 'e';
    comDate[4] = ':';
    comDate[5] = ' ';
    comDate[8] = '/';
    comDate[11] = '/';
    comDate[14] = ' ';
    comDate[15] = ' ';
   // Get Minutes
    tmp = RTCRegRead(0x01);
    time[10] = (tmp & 0x0F) + 0x30;
    time[9] = (tmp >> 4) + 0x30;
    // Get Hours
    tmp = RTCRegRead(0x02);
    time[7] = (tmp & 0x0F) + 0x30;
    time[6] = ((tmp >> 4) & 0x01 ) + 0x30;
    // GET AM or PM (already read register 0x02)
    time[12] = ((tmp >> 4) & 0x01 ) + 0x30;
    if(time[12] == 0){
        time[12]='A';
    } else {
        time[12]='P';
    //Get Month
    tmp = RTCRegRead(0x05);
    comDate[6] = (tmp >> 4) + 0x30 ;
    comDate[7] = (tmp & 0x0F) + 0x30 ;
    //Get Date(day)
    tmp = RTCRegRead(0x04);
    comDate[9] = (tmp >> 4) + 0x30 ;
    comDate[10] = (tmp & 0x0F) + 0x30 ;
    //Get Year
    tmp = RTCRegRead(0x06);
    comDate[12] = (tmp >> 4) + 0x30 ;
    comDate[13] = (tmp & 0x0F) + 0x30 ;
	lcd_line(2);
	lcd_string(time);
	lcd_line(1);
    if(view == 0){
    } else {
    decMonth = bcd2dec(RTCRegRead(0x05), 2);
    decDate  = bcd2dec(RTCRegRead(0x04), 0);
    decYear  = bcd2dec(RTCRegRead(0x06), 0);
    decHour  = bcd2dec(RTCRegRead(0x02),1);
    decMin   = bcd2dec(RTCRegRead(0x01),3);
    decAPM   = bcd2dec(RTCRegRead(0x05),0);
    decAPM   = (decAPM >> 4) & 0x01;
            Show Menu
void ShowMenu(void){
char MyButton = 0;
char views = 1;
myTmp = setupBtn;
while(myTmp == setupBtn){myTmp = Button};
while(1){
    MyButton = Button;
lcd_line(1);
lcd_string(SetStr);
lcd_line(2);
    switch(views){
        case 1:
            lcd_string(TimeStr);
            break;
        case 2:
            lcd_string(DateStr);
            break;
        case 3:
            lcd_string(AlarmStr);
            break;
    switch(MyButton){
        case upBtn:
            if(views>3)
                views = 1;
            else
                views++;
            break;
        case downBtn:
            if(views<1)
                views = 3;
            else
                views--;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            switch(views){
                case 1:
                    SetTime('t');
                    break;
                case 2:
                     break;
                case 3:
                   SetTime('a');
                   break;
            break;
    delay_ms(200);
            Set the Time
void SetTime(char type){
char MyButton = 0;
char views;
myTmp = selectBtn;
views = 1;
if(type == 't'){
    string2[0] = 'T';
    string2[1] = 'i';
    string2[2] = 'm';
    string2[3] = 'e';
    string2[4] = ':';
    string2[5] = ' ';
} else {
    string2[0] = 'A';
    string2[1] = 'l';
    string2[2] = 'a';
    string2[3] = 'r';
    string2[4] = 'm';
    string2[5] = ':';
    string2[6] = ' ';
    string2[9] = ':';
    string2[12] = ' ';
    string2[14] = 'M';
    string2[15] = ' ';
while(1){
    MyButton = Button;
    switch(MyButton){
        case upBtn:
            switch(views){
                case 1:
                    decHour++;
                    break;
                case 2:
                    decMin++;
                    break;
                case 3:
                    decAPM++;
                    break;
            break;
        case downBtn:
            switch(views){
                case 1:
                    decHour--;
                    break;
                case 2:
                    decMin--;
                    break;
                case 3:
                    decAPM--;
                    break;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            views++;
            break;
    if(decHour > 12) decHour = 1;
    if(decHour <= 0) decHour = 12;
    if(decMin > 59) decMin = 0;
    if(decMin < 0) decMin = 59;
    if(decAPM > 2) decAPM = 0;
    if(decAPM < 0) decAPM = 1;
    //Minutes
    myTmp = uint2bcd(decMin);
    string2[10] = (myTmp >> 4) + 0x30;
    string2[11] = (myTmp & 0x0F) + 0x30;
    //Hours
    myTmp = uint2bcd(decHour);
    string2[7] = ((myTmp >> 4) & 0x01) + 0x30;
    string2[8] = (myTmp & 0x0F) + 0x30;
    //AM-PM
    if(decAPM == 0)
        string2[13] = 'A';
    else
        string2[13] = 'P';
    switch(views){
        case 1:
            SetTA[9] = 'H';SetTA[10] = 'o';SetTA[11] = 'u';SetTA[12] = 'r';SetTA[13] = ' ';
            break;
        case 2:
            SetTA[9] = 'M';SetTA[10] = 'i';SetTA[11] = 'n';SetTA[12] = ' ';SetTA[13] = ' ';
            break;
        case 3:
            SetTA[9] = 'A';SetTA[10] = 'M';SetTA[11] = '/';SetTA[12] = 'P';SetTA[13] = 'M';
            break;
    lcd_line(1);
    lcd_string(SetTA);
    lcd_line(2);
    lcd_string(string2);
    delay_ms(200);
    if(views >= 4) break;
    if(decAPM == 0)
        BcdHour = uint2bcd(decHour) | 0b01000000;
    else
        BcdHour = uint2bcd(decHour) | 0b01100000;
    BcdMin = uint2bcd(decMin) & 0b01111111;
    BcdSec = 0x00;
    if(type == 't'){
        RTCRegWrite(0x80,BcdSec);
        RTCRegWrite(0x81,BcdMin);
        RTCRegWrite(0x82,BcdHour);
    } else {
        RTCRegWrite(0x87,BcdSec);
        RTCRegWrite(0x88,BcdMin);
        RTCRegWrite(0x89,BcdHour);
        RTCRegWrite(0x8A,0x80);
            Set the Date
            Interrupt Code
void low_isr (void)
    myTmp = PORTB;
    UpdateTime();
    INTCON3 = 0x98;
    myTmp = PORTB;
    alarmOut = 1;
    UpdateTime();
    RTCRegRead(0x07);
    INTCON3 = 0x98;
compete Rev 2 code: (new schematic coming soon!):
 *          AtomSoft Clock Using PIC18F248, DS1306, 74LS164, 3v Buzzer
 * FileName:        main.c
 * Compiler:        C18
 * Version:         2.0.0
#include <stdio.h>
#include <delays.h>
#include <spi.h>
Prototypes
void main(void);
void initSPI(void);
void e_togg(void);
char readBtn(void);
void low_isr(void);
void SetDate(void);
Definitions
#define upBtn       0x04
Variables
/*       NEW VARs       */
unsigned char BcdDate;
unsigned char BcdMonth;
unsigned char BcdYear;
unsigned char view;
Main
void main(void) {
    ADCON1 = 0x0E;
    initSPI();
	lcd_init();
    SDL_T = 1;
    alarmIn_T = 1;
    OneHz_T = 1;
    alarmOutT = 0;
    alarmOut = 0;
    RCON = 0x80;
    INTCON = 0xC0;
    INTCON2 = 0x80;
    INTCON3 = 0x98;
    UpdateTime();
    view = 0;
    RTCRegRead(0x07);
    while(1) {
        myTmp = Button;
            if(view == 1){
                view = 0;
            } else {
                view = 1;
            UpdateTime();
            INTCON = 0x00;
            ShowMenu();
            UpdateTime();
            delay_s(1);
            INTCON = 0xC0;
        if(myTmp == upBtn){
            alarmOut = 0;
RTC Tools
    char x;
    switch(type){
        case 0:
            highNyb &= 0x0F;
            break;
        case 1:
            highNyb &= 0x01;
            break;
        case 2:
            highNyb &= 0x03;
            break;
        case 3:
            highNyb &= 0x07;
            break;
        case 4:
            highNyb &= 0x00;
            break;
        MyDec += 10;
    return MyDec;
    char tmp;
    CS = 1;
        tmp = ReadSPI();
    CS = 0;
    return tmp;
    CS = 1;
        WriteSPI(data);
    CS = 0;
Initialize SPI
void initSPI(void){
    CS = 1;
        WriteSPI(0x8F);
        WriteSPI(0x00);
    CS = 0;
LCD Functions
Send String to LCD
    delay_ms(1);
		senpoint++;
	int i;
			LCD_DAT=1;
		else
			LCD_DAT=0;
		dNyb=dNyb<<1;
	LCD_DAT = 0;
	e_togg();
Toggle E Line
void e_togg(void){
	LCD_E=1;LCD_E=0;
Set LCD Line
    if(line == 0x01)
        lcd_cmd(0x80);
    else
	    lcd_cmd(0xc0);
LCD Send Command
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,0);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,0);
LCD Send Character
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,1);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,1);
LCD Initialization
    LCD_E_T = 0;
    LCD_CLK_T = 0;
    LCD_DAT_T = 0;
	lcdByte(0x03,0);
	delay_ms(5);
	e_togg();
	delay_us(160);
	e_togg();
	delay_us(160);
	lcdByte(0x02,0);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_ms(500);
    Delay Second(s)
    int y;
    char x;
    for(y=0;y<S;y++)
        for(x=0;x<4;x++)
            delay_ms(250);
    int y;
    for(y=0;y<mS;y++)
        Delay1KTCYx(5);
    Delay MicroSeconds
symbol for Micro
    int y;
    char x;
    for(y=0;y<uS;y++)
        for(x=0;x<5;x++)
            Nop();
readBtn
char readBtn(void){
    char tmpA;
    return tmpA;
LCD / RTC stuff
    char i;
    time[0] = 'T';
    time[1] = 'i';
    time[2] = 'm';
    time[3] = 'e';
    time[4] = ':';
    time[5] = ' ';
    time[8] = ':';
    time[11] = ' ';
    time[13] = 'M';
    time[14] = ' ';
    time[15] = ' ';
    // Get Date
    comDate[0] = 'D';
    comDate[1] = 'a';
    comDate[2] = 't';
    comDate[3] = 'e';
    comDate[4] = ':';
    comDate[5] = ' ';
    comDate[8] = '/';
    comDate[11] = '/';
    comDate[14] = ' ';
    comDate[15] = ' ';
   // Get Minutes
    // Get Hours
    if(time[12] == 0){
        time[12]='A';
    } else {
        time[12]='P';
    //Get Month
    //Get Date(day)
    //Get Year
	lcd_line(2);
	lcd_string(time);
	lcd_line(1);
    if(view == 0){
    } else {
            Show Menu
char MyButton = 0;
char views = 1;
myTmp = setupBtn;
while(1){
    MyButton = Button;
lcd_line(1);
lcd_string(SetStr);
lcd_line(2);
    switch(views){
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
    switch(MyButton){
        case upBtn:
            if(views>3)
                views = 1;
            else
                views++;
            break;
        case downBtn:
            if(views<1)
                views = 3;
            else
                views--;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            switch(views){
                case 1:
                    SetTime('t');
                    break;
                case 2:
                    SetDate();
                     break;
                case 3:
                   SetTime('a');
                   break;
            break;
    delay_ms(200);
            Set the Time
char MyButton = 0;
char views;
myTmp = selectBtn;
views = 1;
if(type == 't'){
    string2[0] = 'T';
    string2[1] = 'i';
    string2[2] = 'm';
    string2[3] = 'e';
    string2[4] = ':';
    string2[5] = ' ';
} else {
    string2[0] = 'A';
    string2[1] = 'l';
    string2[2] = 'a';
    string2[3] = 'r';
    string2[4] = 'm';
    string2[5] = ':';
    string2[6] = ' ';
    string2[9] = ':';
    string2[12] = ' ';
    string2[14] = 'M';
    string2[15] = ' ';
while(1){
    MyButton = Button;
    switch(MyButton){
        case upBtn:
            switch(views){
                case 1:
                    decHour++;
                    break;
                case 2:
                    decMin++;
                    break;
                case 3:
                    decAPM++;
                    break;
            break;
        case downBtn:
            switch(views){
                case 1:
                    decHour--;
                    break;
                case 2:
                    decMin--;
                    break;
                case 3:
                    decAPM--;
                    break;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            views++;
            break;
    //Minutes
    //Hours
    //AM-PM
    if(decAPM == 0)
        string2[13] = 'A';
    else
        string2[13] = 'P';
    switch(views){
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
    lcd_line(1);
    lcd_string(SetTA);
    lcd_line(2);
    delay_ms(200);
    if(decAPM == 0)
    else
    BcdSec = 0x00;
    if(type == 't'){
    } else {
            Set the Date
void SetDate(void){
char MyButton = 0;
char views;
myTmp = selectBtn;
views = 1;
    string2[0] = 'D';
    string2[1] = 'a';
    string2[2] = 't';
    string2[3] = 'e';
    string2[4] = ':';
    string2[5] = ' ';
while(1){
    MyButton = Button;
    switch(MyButton){
        case upBtn:
            switch(views){
                case 1:
                    decMonth++;
                    break;
                case 2:
                    decDate++;
                    break;
                case 3:
                    decYear++;
                    break;
            break;
        case downBtn:
            switch(views){
                case 1:
                    decMonth--;
                    break;
                case 2:
                    decDate--;
                    break;
                case 3:
                    decYear--;
                    break;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            views++;
            break;
    if(decYear > 99) decYear = 1;
    if(decYear <= 0) decYear = 99;
    if(decDate > 31) decDate = 1;
    if(decDate <= 0) decDate = 31;
    if(decMonth > 12) decMonth = 1;
    if(decMonth <= 0) decMonth = 12;
    //Month
    myTmp = uint2bcd(decMonth);
    string2[6] = (myTmp >> 4) + 0x30;
    string2[7] = (myTmp & 0x0F) + 0x30;
    string2[8] = '/';
    //Date
    myTmp = uint2bcd(decDate);
    string2[9] = (myTmp >> 4) + 0x30;
    string2[10] = (myTmp & 0x0F) + 0x30;
    string2[11] = '/';
    //Year
    myTmp = uint2bcd(decYear);
    string2[12] = (myTmp >> 4) + 0x30;
    string2[13] = (myTmp & 0x0F) + 0x30;
    switch(views){
        case 1:
            SetTA[9] = 'M';SetTA[10] = 'o';SetTA[11] = 'n';SetTA[12] = 't';SetTA[13] = 'h';
            break;
        case 2:
            SetTA[9] = 'D';SetTA[10] = 'a';SetTA[11] = 't';SetTA[12] = 'e';SetTA[13] = ' ';
            break;
        case 3:
            SetTA[9] = 'Y';SetTA[10] = 'e';SetTA[11] = 'a';SetTA[12] = 'r';SetTA[13] = ' ';
            break;
    lcd_line(1);
    lcd_string(SetTA);
    lcd_line(2);
    delay_ms(200);
    BcdMonth = uint2bcd(decMonth);
    BcdDate  = uint2bcd(decDate);
    BcdYear  = uint2bcd(decYear);
        RTCRegWrite(0x85,BcdMonth);
        RTCRegWrite(0x84,BcdDate);
        RTCRegWrite(0x86,BcdYear);
            Interrupt Code
void low_isr (void)
    myTmp = PORTB;
    UpdateTime();
    INTCON3 = 0x98;
    myTmp = PORTB;
    alarmOut = 1;
    UpdateTime();
    RTCRegRead(0x07);
    INTCON3 = 0x98;
Here is a picture of it in prototype form. Ill post a video soon.
EDIT: Video:
[embed]http://www.youtube.com/v/VT9xQCN-DUo[/embed]
New code with commented updates:(REV:3)
 * FileName:        main.c
 * Compiler:        C18
 * Version/Rev:     3.0.0
    Changes in V3.
    1. Alarm Beeps 4 times a second and is in interrupt.
    2. Cleaned up code a bit.
    3. Fixed LCD string mistake in date.
    4. Finishing a Setup now takes you back to main menu.
    5. Insuring that the Alarm Flag is cleared:
       "IRQF0 is cleared when the address pointer goes to any of
        the Alarm 0 registers during a read or write"
#include <stdio.h>
#include <delays.h>
#include <spi.h>
Prototypes
void main(void);
void initSPI(void);
void e_togg(void);
char readBtn(void);
void low_isr(void);
void SetDate(void);
Definitions
#define upBtn       0x04
Variables
/*       NEW VARs       */
unsigned char view;
unsigned char AlarmSet;
Main
void main(void) {
    char x;
    AlarmSet = 0;
    ADCON1 = 0x0E;
    initSPI();
	lcd_init();
    SDL_T = 1;
    alarmIn_T = 1;
    OneHz_T = 1;
    alarmOutT = 0;
    alarmOut = 0;
    RCON = 0x80;
    INTCON = 0xC0;
    INTCON2 = 0x80;
    INTCON3 = 0x98;
    UpdateTime();
    view = 0;
    while(1) {
        myTmp = Button;
            if(view == 1){
                view = 0;
            } else {
                view = 1;
            UpdateTime();
            INTCON = 0x00;
            ShowMenu();
            UpdateTime();
            delay_s(1);
            INTCON = 0xC0;
        if(myTmp > 0x00){
            alarmOut = 0;
            AlarmSet = 0;
            myTmp = RTCRegRead(0x0A);       //Clear the flag in DS1306 (IRQF0)
RTC Tools
    char x;
    switch(type){
        case 0:
            highNyb &= 0x0F;
            break;
        case 1:
            highNyb &= 0x01;
            break;
        case 2:
            highNyb &= 0x03;
            break;
        case 3:
            highNyb &= 0x07;
            break;
        case 4:
            highNyb &= 0x00;
            break;
        MyDec += 10;
    return MyDec;
    char tmp;
    CS = 1;
        tmp = ReadSPI();
    CS = 0;
    return tmp;
    CS = 1;
        WriteSPI(data);
    CS = 0;
Initialize SPI
void initSPI(void){
    CS = 1;
        WriteSPI(0x8F);
        WriteSPI(0x00);
    CS = 0;
LCD Functions
Send String to LCD
    delay_ms(1);
		senpoint++;
	int i;
			LCD_DAT=1;
		else
			LCD_DAT=0;
		dNyb=dNyb<<1;
	LCD_DAT = 0;
	e_togg();
Toggle E Line
void e_togg(void){
	LCD_E=1;LCD_E=0;
Set LCD Line
    if(line == 0x01)
        lcd_cmd(0x80);
    else
	    lcd_cmd(0xc0);
LCD Send Command
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,0);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,0);
LCD Send Character
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,1);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,1);
LCD Initialization
    LCD_E_T = 0;
    LCD_CLK_T = 0;
    LCD_DAT_T = 0;
	lcdByte(0x03,0);
	delay_ms(5);
	e_togg();
	delay_us(160);
	e_togg();
	delay_us(160);
	lcdByte(0x02,0);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_us(160);
	delay_ms(500);
    Delay Second(s)
    int y;
    char x;
    for(y=0;y<S;y++)
        for(x=0;x<4;x++)
            delay_ms(250);
    int y;
    for(y=0;y<mS;y++)
        Delay1KTCYx(5);
    Delay MicroSeconds
symbol for Micro
    int y;
    char x;
    for(y=0;y<uS;y++)
        for(x=0;x<5;x++)
            Nop();
readBtn
char readBtn(void){
    char tmpA;
    return tmpA;
LCD / RTC stuff
    char i;
    time[0] = 'T';
    time[1] = 'i';
    time[2] = 'm';
    time[3] = 'e';
    time[4] = ':';
    time[5] = ' ';
    time[8] = ':';
    time[11] = ' ';
    time[13] = 'M';
    time[14] = ' ';
    time[15] = ' ';
    // Get Date
    comDate[0] = 'D';
    comDate[1] = 'a';
    comDate[2] = 't';
    comDate[3] = 'e';
    comDate[4] = ':';
    comDate[5] = ' ';
    comDate[8] = '/';
    comDate[11] = '/';
    comDate[14] = ' ';
    comDate[15] = ' ';
   // Get Minutes
    // Get Hours
    time[12] = (tmp >> 4) & 0x02;
    if(time[12] == 0){
        time[12]='A';
    } else {
        time[12]='P';
    //Get Month
    //Get Date(day)
    //Get Year
	lcd_line(2);
	lcd_string(time);
	lcd_line(1);
    if(view == 0){
    } else {
    decAPM   = (decAPM >> 5) & 0x01;
            Show Menu
char MyButton = 0;
char views = 1;
myTmp = setupBtn;
while(1){
    MyButton = Button;
lcd_line(1);
lcd_string(SetStr);
lcd_line(2);
    switch(views){
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
    switch(MyButton){
        case upBtn:
            if(views>3)
                views = 1;
            else
                views++;
            break;
        case downBtn:
            if(views<1)
                views = 3;
            else
                views--;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            switch(views){
                case 1:
                    SetTime('t');
                    break;
                case 2:
                    SetDate();
                     break;
                case 3:
                    SetTime('a');
                    break;
            break;
    delay_ms(200);
            Set the Time
char MyButton = 0;
char views;
myTmp = selectBtn;
views = 1;
if(type == 't'){
    string2[0] = 'T';
    string2[1] = 'i';
    string2[2] = 'm';
    string2[3] = 'e';
    string2[4] = ':';
    string2[5] = ' ';
} else {
    string2[0] = 'A';
    string2[1] = 'l';
    string2[2] = 'a';
    string2[3] = 'r';
    string2[4] = 'm';
    string2[5] = ':';
    string2[6] = ' ';
    string2[9] = ':';
    string2[12] = ' ';
    string2[14] = 'M';
    string2[15] = ' ';
while(1){
    MyButton = Button;
    switch(MyButton){
        case upBtn:
            switch(views){
                case 1:
                    decHour++;
                    break;
                case 2:
                    decMin++;
                    break;
                case 3:
                    decAPM++;
                    break;
            break;
        case downBtn:
            switch(views){
                case 1:
                    decHour--;
                    break;
                case 2:
                    decMin--;
                    break;
                case 3:
                    decAPM--;
                    break;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            views++;
            break;
    if(decAPM > 1) decAPM = 0;
    //Minutes
    //Hours
    //AM-PM
    if(decAPM == 0)
        string2[13] = 'A';
    else
        string2[13] = 'P';
    switch(views){
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
    lcd_line(1);
    lcd_string(SetTA);
    lcd_line(2);
    delay_ms(200);
    if(decAPM == 0)
    else
    BcdSec = 0x00;
    if(type == 't'){
    } else {
            Set the Date
void SetDate(void){
char MyButton = 0;
char views;
myTmp = selectBtn;
views = 1;
    string2[0] = 'D';
    string2[1] = 'a';
    string2[2] = 't';
    string2[3] = 'e';
    string2[4] = ':';
    string2[5] = ' ';
while(1){
    MyButton = Button;
    switch(MyButton){
        case upBtn:
            switch(views){
                case 1:
                    decMonth++;
                    break;
                case 2:
                    decDate++;
                    break;
                case 3:
                    decYear++;
                    break;
            break;
        case downBtn:
            switch(views){
                case 1:
                    decMonth--;
                    break;
                case 2:
                    decDate--;
                    break;
                case 3:
                    decYear--;
                    break;
            break;
        case setupBtn:
            return;
            break;
        case selectBtn:
            views++;
            break;
    //Month
    string2[8] = '/';
    //Date
    string2[11] = '/';
    //Year
    string2[14] = string2[15] = ' ';        //String FIX! in Rev. 3
    switch(views){
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
    lcd_line(1);
    lcd_string(SetTA);
    lcd_line(2);
    delay_ms(200);
            Interrupt Code
void low_isr (void)
    char x;
    if(AlarmSet == 1){
       for(x=0;x<4;x++){
            alarmOut = 1;
            delay_ms(100);
            alarmOut = 0;
            delay_ms(100);
    myTmp = PORTB;
    UpdateTime();
    INTCON3 = 0x98;
    myTmp = PORTB;
    AlarmSet = 1;
    UpdateTime();
    RTCRegRead(0x07);
    INTCON3 = 0x98;
here is a better picture.. my camera came in yay! i took a nice picture of a IC also to test the depth of the picture lol
Excellent! What camera did you get?
What's all the mung in the IC macro photo? :D That's a dirty, dirty breadboard. It looks like you been eating crackers over it. :p
Mine always have cat hair when I zoom in close.
Whats MUNG?
Unidentified icky stuff?
In some circles 'mung' is used as a word meaning foul material covering on a surface, i.e., "you've got some mung in between your teeth" or "you left your mung on my table." Military mechanics loosely use the term to refer to a combination of axle grease, mud, and dead things that were crushed under the equipment, and anything else that is generally left to be sprayed off by the lowest ranking shop worker. This concept has spawned cast-offs, implying that anything that is supremely disgusting can be said to be "mung".
Nice price on the camera. Would make a good "beater" for places I don't want to take my good camera. Decent macro shots.
yeah it said 5cm but that was about 3cm distance. It does awesome nice video also. (mainly of people) Close up video is decent. Ill post something on youtube in a minute
You have inspired me :) Santa brought me a Samsung L200. Up to now I have not taken the time to mess with more then point and shoot. You closeup looked so good I had to give it a try. The auto focus in close is a bit hit and miss. I did not manage to get in as close as yours. Good work :)
Up to now I had left the bit of clingy plastic covering the LCD. It made a nice but foggy protector.
3v0
hey some of you know i have been working on a clock using a DS1306 and i wanted to post this for anyone who wants to see it. at the moment you can only set the time. Its a huge file.
You can study about BCD conversions, SPI, Shift Registers(74LS165 & 74LS164). I say you can study mainly because it all works so far. And if it works then maybe it can help some people.
Im in the process of adding code to Set the Date including Day, month, year, actual day... take a look.
I rewrote my old code. This should be a nice read for some.
I used DS1307 earlier with 89C2051 MC and it worked displaying clock and calendar. That was a few years back. Now I have been going through it again . I could write to DS1307 and read and display the contents. But the clock is not running itself. I made the CH bit 0. Can you give me any other hint. I am just on that job
i dont want to kill the sites bandwidth. If i was to post so many pictures on the site it would increase its bandwidth and may increase or help to create that issue.
premkumar9: I have used some other clocks but never the DS1307 ill check the datasheet and see what you are refering to.
But can you please explain it better.
EDIT
It sounds like you have a OSC issue. Are you sure the Crystal is good?
A few pictures aren't going to cause any problems :D
By posting external links it means the pictures will disappear, making nonsense of the posts.
ive had pictures on photobucket for years now. I dont think they are leaving anytime soon :D But I always keep the images on my PC anyway even if crap. So i can replace em in the future :)
I understand what you are saying but.
Who knows how long photobucket will be around. They could close up shop without notice. If you are anything like me I would not have a lot of motivation to search for all my posts with attachments, find the right image on my PC and upload them.
In the end Nigel is correct.
3v0
