Clock
Mike so your saying just use that output of 1hz to count and stuff.
What would be the fun in that? :D
If you want to scrap the DS1306, I would just use a 32Khz crystal with the Timer1/oscillator/CCP for my 1 second interrupt.
You'd still need to read the RTC chip on "power up" and you'd still need to update the RTC chip after some "set" operations. Other then that, yes, you could have a complete Clock/Calendar/Alarm/Timer system running off of the RTC chip 1 Hz interrupt.
As for the length of your program, you'll find methods to reduce the size of your code as you gain experience. For example, you might find that you can use a small generic "set" routine for setting the Clock, Calendar, Alarm, or Timer. Simply design the "set" routine to operate on a fixed buffer and copy the target buffer (Clock, Calendar, Alarm, etc.) into this buffer at the start of the routine and then copy the data in the fixed buffer back to the target buffer at the end of the routine. Here's an example from my Charlie Clock demo that uses the <up> <down> and <right> arrow keys (the <left> arrow is actually the 'set' switch). The keys are sampled and debounced in the interrupt handler so I simply sample the switch flag bits here in Main.
    if(setmode & mode < 3)      // if set switch and display "on"
    { loadbuffer();             // copy source array to set[] buffer
      group = 0;                // set starting group (hours/months)
      setlimits();              // set lower/upper field limits
      while(setmode)            // while set switch "on"
      { if(rtarrow)             // if rt arrow
        { rtarrow = 0;          //
          if(group == 2)        // bump display group, 0..2
            group = 0;          //
          else                  //
            group++;            //
        while(uplatch)          // while up arrow pressed
        { uparrow = 0;          // increment display group value
          if(set[group] == hilimit)
            set[group] = lolimit;
          else                  //
            set[group]++;       //
          delay_ms(220);        // delay approx 1/4 sec
          if(uplatch)           // if still pressed
            beepctr = 16;       // send repeat 'click'
        while(dnlatch)          // while dn arrow pressed
        { dnarrow = 0;          // decrement display group value
          if(set[group] == lolimit)
            set[group] = hilimit;
          else                  //
            set[group]--;       //
          if(dnlatch)           // if still pressed
      intcon.GIE = 0;           // suspend interrupts
      savebuffer();             // copy set[] buffer to source array
      if(mode == 0)             // if 'clock' was 'source' then
      { rtcl = 25;              // reset RTC counters including
        rtch = 0;               // set switch debounce time...
      intcon.GIE = 1;           // restart interrupts
pretty cool. I am rewiring my whole project and am going to rewrite the entire code again lol. I feel that if i rewrite it i can change things better and remove the useless stuff.
Like in my main code i will only have the function to check buttons pressed. I will use the interrupt (1hz) to trigger a interrupt on PIC and in code set it to read the RTC and PARSE the data read into a Variable(array) of fixed length.
I guess i need to learn about combining strings and stuff more to reduce code and complexity. I am only using the SN74LS164 for the LCD to work on 2 wires (3 with E toggle).
I will use the RA0:RA3 for button input.
RB3 might be for Buzzer.
The entire PORTC is used for LCD, 74LS164 and DS1306. RC7 is free i might use it for buzzer instead. I will have a complete PORTB in which i will use for interrupts and such. I will start tomorrow morning.
Any Tips or thoughts on the above?
Hi Eric,
Just wondering why you would read date & time on every 1 second interrupt?
Mike
hi Mike.
Obviously reading the TIME once/sec is essential if you are displaying hh:mm:ss.
For the very small 'timing' overhead its just as easy to read the DATE in the same interrupt, even though the DATE may not displayed every second.
If the user presses 'show DATE' its in the buffer, rather than having to do extra program steps to read the DATE and then display it.
The other point is, some of the 'alarm states' may cross the midnight time slot, so by reading the DATE during the TIME interrupt
the 'alarms' are tested for the midnight boundary.
Hope this is clear.:)
That would eliminate the whole 2100 year issue and all BCD problems completely. Since i would be writing the code myself. Which means i wouldnt even have to use the RTC SPI lines besides having to program the 1hz to operational. Thats pretty cool idea. I have another 1306 Ill play with that idea on another pic. I have another LCD and some more sn74LS164's so ill be good to make another and try it out.
hi atom.
Sadly the chances are, you and the products that you design today, will not be around at the turn of the century.:(
I would suggest you forget the 20xx part of the DATE, any user with common sense will know that 28:12:08 [UK format] is the year 2008.
anyone in there right mind wouls know what year it is also lol but i understand the benefits of using just
12/28/08 (US)
Still having entire code in PIC saves alot of reading to from the Ds1306 and if one can eliminate it period by using a 1hz on a interrupt i dont see the issue. The DS1306 i guess is for ease of use type work to simplify or shorten code for some.
I find the idea of having a 1hz crystal way better than a 1306 altogether. Even tho i have to create the months and days and years my self thats really not a issue. And to remove cost from this clock i should remove the DS1306 completely but i wont since i dont have a 1hz crystal.
Edit: Removing the DS1306 also simplifies the Layout of PCB
12/28/08 (US)
If you go for a software clock you will require a PIC with battery back up, else you will loose the date/time.
The HEF4060 will divide down [32.768KHz xtal] to 2Hz.
Or use the 32Khz xtal on one of the PIC Timers
Jason,
I agree, and I suspect that's why I haven't tried using the DS1307 samples yet.
In my opinion, the only advantage of an RTC chip is that you can use the battery backup to prevent losing the time.
Otherwise, code for the Clock, a perpetual Calendar, Day-of-week, Alarm, Appliance Timer, etc., are a breeze and can be re-used with a relatively simple driver for almost any type of display (7-segment, LCD, or dot-matrix).
Mike
hi Mike,
The only counter point I would make against a software date/time is that Jason IIRC, is making this clock only a small part of a bigger project.
His full system dosnt want to be hung up servicing a SW clock.
I have used 1sec S/W clocks in the past I would consider that if was just a RTC clock display it wouldnt be a problem.
I would like you to stay with the DS1306. Once that works can build a clock with a PIC. But slay the dragon in front of you first.
Your are following a pattern typical or people who are learning. Instead of solving the problem(s) you are switching to another design. To use the 1hz or no clock you have to write clock code for the PIC. Why is that better then fixing the code you already have. It is more work because you will have to write and debug new code.
There are two ways to use the clock. One is like a clock on the wall. It knows and shows the time, all the time. The other is more useful in the uC world. We use the external clock as an alarm clock. We ignore the time and have it tell us when it is time to act. It allocates the work of time keeping to the clock. It distributes the work.
The clock alarm can be wired as an external interrupt to the PIC. To do a task at a given time you set the clock's alarm and forget about it up to the point when the interrupt happens. This is a very nice thing, you seldom have reason to read the clock.
3v0
Hi Eric,
Honestly I don't see the problem. We're really only talking about a handful of instructions executed once/second (very low 'overhead').
The 'overhead' is so low that I'm thinking about building in Clock/Calendar functions into a PIC based Serial LCD Controller.
static unsigned char RTC [] = { 59, 59, 23 };   // secs, mins, hours
static unsigned char TMR [] = { 00, 00, 23 };   // secs, mins, hours
static unsigned char ALM [] = { 59, 59, 23 };   // secs, mins, hours
static unsigned char CAL [] = { 01, 31, 08 };   // month, day, year
const rom unsigned char DTbl [] = { 29,     // February (leap yr)
                                    31,     // January
                                    28,     // February
                                    31,     // March
                                    30,     // April
                                    31,     // May
                                    30,     // June
                                    31,     // July
                                    31,     // August
                                    30,     // September
                                    31,     // October
                                    30,     // November
                                    31 };   // December
#define Month CAL[0]
#define Day CAL[1]
#define Year CAL[2]
#define FebruaryLeap !(Year%4 || Month^2)
      *  Bump Real Time Clock and Calendar (ISR excerpt)         *
      n = 0;                    // index seconds array element
      while(RTC[n]++ == 59)     // while value 59 (post inc value)
        RTC(n++) = 0;           // set to 00 and bump array index
      if(RTC[2] == 24)          // change 24:00:00 to 00:00:00
      { RTC[2] = 0;             // and bump the Calendar
        n = Month;              // use Month 1..12 for index
        if(FebruaryLeap)        // if leap year and february
          n = 0;                // use 0 for day table index
        if(Day++ == DTbl[n])    // if last day of month
        { Day = 1;              // set day to 1 and
          if(Month++ == 12)     // if end of year
          { Month = 1;          // set month to january and
            Year++;             // increment year and
            Year %= 100;        // keep it in 00..99 range
      *  Alarm                                                   *
      if(AlarmEnabled)          // if Alarm enabled
      { if(RTC[2] == ALM[2])    // if hours match and
          if(RTC[1] == ALM[1])  // if minutes match
            AlarmFlag = 1;      // turn on alarm spkr output
      *  Count Down Timer / Appliance Timer                      *
      if(TimerEnabled)          // if Count Down Timer enabled
      { n = 0;                  // index seconds array element
        while (!TMR[n]--)       // while value 00 (post dec value)
          TMR[n++] = 59;        // set to 59 and bump array index
        if (!(TimerEnabled = TMR[0]||TMR[1]||TMR[2]))
        {                       // do timed out functions here
3v0: I am not switching over without solving a issue. The entire clock works fine. Now that it does i am trying something new. This something new is just the same thing but instead of reading buttons using the "165" im doing it with PORTA and instead of reading time all the time :) im redaing it using the 1hz interrupt.
I will still use the DS1306 as a clock since it does reduce the actual work of me having to make the entire thing and it as that battery backup which i can place a battery, no issue.
This is INDEED just a clock. But the thing is i do plan to mix it into another project in future. (security system) and even if i did it on a pic i can make the pic accept SPI commands as a slave and basically make my own type of DS1306 with my own code hence i dont have to do any BCD at all.
But for now i plan to ues this DS1306 since i got it :D
here is new my REV 2 schematic. I made the schematic first so i can follow it better when writing code.
I must have missed that part :) You have a tendency to rush from one project to another. At some point soon you need to take the time to get it right. Upgrade you coding skills. I am amazed at how fast you have progressed. Take this as a pointer or concern on my part, not a negative comment.
3v0
i will surely take it as a pointer although i will also address it as a concern. I will work on sticking to 1 thing for long enough to ensure i understand it to the point where i dont get lost as much. I will also try to up my coding skills as to minimize size and time. I always take anything said whether good or bad about me as something good. If i did something bad that means i am trying at least if i did something good it means i tried and succeeded.Thanks again. I will stay on this clock for at least 3-5 more days until i feel that its something i think i and/or someone would like/buy.
Even tho its not for sale its nice to imagine if someone else likes it its a good job done :D
Here is my button setup now. Using RA4:RA1 now.
#define Button      (PORTA >> 1) & 0x0F;
#define Button_T    TRISA
#define setupBtn    0x01
#define downBtn     0x02
#define upBtn       0x04
#define selectBtn   0x08
This is the stripped version which is no where near done. Just here to show progress and changes so far:
 *          AtomSoft Clock Using PIC18F248, DS1306, 74LS164, 74LS165
 * FileName:        main.c
 * Author:          Jason Lopez
 * Processor:       PIC18F248(0)
 * Compiler:        C18
 * Company:         AtomSoftTech
 * Version:         2.0.0
#include <p18F248.h>
#include <stdio.h>
#include <delays.h>
#include <spi.h>
#pragma config WDT = OFF, LVP = OFF, OSC = HS
Prototypes
void main(void);
void initSPI(void);
void e_togg(void);
void lcd_line(char line);
void lcd_cmd(unsigned char letter);
void lcd_char(unsigned char letter);
void lcd_string(char *senpoint);
void lcd_init(void);
void delay_ms(int mS);
void delay_us(int uS);
void delay_s(int S);
void lcdByte(unsigned char dNyb,unsigned char rs);
char RTCRegRead(char adx);
void RTCRegWrite(char adx, char data);
static unsigned char uint2bcd(unsigned char ival);
char readBtn(void);
unsigned char bcd2dec(unsigned char aBCD, char type);
void putDate(char type, char data);
void UpdateTime(void) ;
Definitions
#define CS LATCbits.LATC2
#define CS_T  TRISCbits.TRISC2
#define SCL_T TRISCbits.TRISC3
#define SDA_T TRISCbits.TRISC4
#define SDO_T TRISCbits.TRISC5
#define LCD_DAT_T TRISCbits.TRISC0
#define LCD_CLK_T TRISCbits.TRISC1
#define LCD_DAT LATCbits.LATC0
#define LCD_CLK LATCbits.LATC1
#define LCD_E_T TRISCbits.TRISC6
#define LCD_E   LATCbits.LATC6
#define PL  LATBbits.LATB0
#define CP2 LATBbits.LATB1
#define SDL  PORTBbits.RB2
#define PL_T   TRISBbits.TRISB0
#define CP2_T  TRISBbits.TRISB1
#define SDL_T  TRISBbits.TRISB2
#define upBtn       0x04
#define alarmOut  LATBbits.LATB3
#define alarmOutT TRISBbits.TRISB3
#define alarmIn   TRISBbits.TRISB4
Variables
char string[] =  "                ";
char string2[] = "                ";
unsigned char lDate[16];
unsigned char myTmp;
/*       NEW VARs       */
unsigned char decHour;
unsigned char decMin;
unsigned char decAPM;
unsigned char decDate;
unsigned char decMonth;
unsigned char decYear;
unsigned char time[16];
unsigned char comDate[16];
unsigned char view;
Main
void main(void) {
    ADCON1 = 0x0E;
    initSPI();
	lcd_init();
    SDL_T = 1;
    Button_T = 0xFF;    //TRISA (all input)
    RTCRegWrite(0x8F,0x05);
    UpdateTime();
    view = 0;
    while(1) {
        myTmp = Button;
        if(myTmp == selectBtn){
            if(view == 1){
                sprintf(string,"  AtomSoftTech  ",0);
	            lcd_string(string);
                view = 0;
            } else {
	            lcd_string(comDate);
                view = 1;
            UpdateTime();
            while(myTmp == selectBtn){myTmp = Button};
RTC Tools
Convert Char(byte) to BCD
	return ((ival / 10) << 4) | (ival % 10);
Convert BCD to Char(byte)
    char lowNyb = aBCD & 0x0F;
    char highNyb = aBCD >> 4;
    char MyDec = lowNyb;
    char x;
    switch(type){
        case 0:
            highNyb &= 0x0F;
            break;
        case 1:
            highNyb &= 0x01;
            break;
        case 2:
            highNyb &= 0x03;
            break;
        case 3:
            highNyb &= 0x07;
            break;
        case 4:
            highNyb &= 0x00;
            break;
    for(x=0;x<highNyb;x++){
        MyDec += 10;
    return MyDec;
Read a Register off the DS1306
char RTCRegRead(char adx){
    char tmp;
    CS = 1;
        WriteSPI(adx); //sec
        tmp = ReadSPI();
    CS = 0;
    return tmp;
Write to a Register on the DS1306
void RTCRegWrite(char adx, char data){
    CS = 1;
        WriteSPI((adx | 0x80 ));
        WriteSPI(data);
    CS = 0;
Initialize SPI
void initSPI(void){
    CS_T = 0;       //CS is output
    SCL_T = 0;      //SCL is output
    SDA_T = 1;      //SDA is input
    SDO_T = 0;      //SDO is output
    OpenSPI(SPI_FOSC_4,MODE_10,SMPEND);
    CS = 1;
        WriteSPI(0x8F);
        WriteSPI(0x00);
    CS = 0;
LCD Functions
Send String to LCD
void lcd_string(char *senpoint){
    delay_ms(1);
	while(*senpoint != '\0'){
		lcd_char(*senpoint);
		senpoint++;
Send Data(Nybble) to LCD
void lcdByte(unsigned char dNyb,unsigned char rs){
	int i;
	LCD_DAT=0;							//Clear 74LS164 set initial bit to 0
	for(i=0;i<8;i++){				    //repeat for 8 bits
		LCD_CLK=1;LCD_CLK=0;			//write 0's to the 164
	for(i=0;i<4;i++){				    //output the nybble
		if((dNyb & 0x08) != 0)
			LCD_DAT=1;
		else
			LCD_DAT=0;
		dNyb=dNyb<<1;
	LCD_DAT = rs;						    //output the RS bit value
	LCD_DAT = 0;
	e_togg();
Toggle E Line
void e_togg(void){
	LCD_E=1;LCD_E=0;
Set LCD Line
void lcd_line(char line){
    if(line == 0x01)
        lcd_cmd(0x80);
    else
	    lcd_cmd(0xc0);
LCD Send Command
void lcd_cmd(unsigned char letter){
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,0);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,0);
LCD Send Character
void lcd_char(unsigned char letter){
	unsigned char temp;
	temp=letter;
	temp=temp>>4;
	lcdByte(temp,1);
	temp=letter;
	temp=temp&0x0f;
	lcdByte(temp,1);
LCD Initialization
void lcd_init(void){
    LCD_E_T = 0;
    LCD_CLK_T = 0;
    LCD_DAT_T = 0;
	lcdByte(0x03,0);
	delay_ms(5);
	e_togg();
	delay_us(160);
	e_togg();
	delay_us(160);
	lcdByte(0x02,0);
	delay_us(160);
	lcd_cmd(0x28);					//set 4-bit mode and 2 lines
	delay_us(160);
	lcd_cmd(0x10);					//cursor move & shift left
	delay_us(160);
	lcd_cmd(0x06);					//entry mode = increment
	delay_us(160);
	lcd_cmd(0x0d);					//display on - cursor blink on
	delay_us(160);
	lcd_cmd(0x01);					//clear display
	delay_ms(500);
Delays (S,mS,uS) for 20Mhz
    Delay Second(s)
void delay_s(int S){
    int y;
    char x;
    for(y=0;y<S;y++)
        for(x=0;x<4;x++)
            delay_ms(250);
    Delay MilliSecond(s)
void delay_ms(int mS){
    int y;
    for(y=0;y<mS;y++)
        Delay1KTCYx(5);
    Delay MicroSeconds
Lowercase 'u' is common
symbol for Micro
void delay_us(int uS){
    int y;
    char x;
    for(y=0;y<uS;y++)
        for(x=0;x<5;x++)
            Nop();
readBtn
char readBtn(void){
    return Button;
LCD / RTC stuff
void UpdateTime(void) {
    unsigned char tmp,tmp2;
    char i;
    // Fill In the LCD String
    time[0] = 'T';
    time[1] = 'i';
    time[2] = 'm';
    time[3] = 'e';
    time[4] = ':';
    time[5] = ' ';
    time[8] = ':';
    time[11] = ' ';
    time[13] = 'M';
    time[14] = ' ';
    time[15] = ' ';
    // Get Date
    comDate[0] = 'D';
    comDate[1] = 'a';
    comDate[2] = 't';
    comDate[3] = 'e';
    comDate[4] = ':';
    comDate[5] = ' ';
    comDate[8] = '/';
    comDate[11] = '/';
    comDate[14] = ' ';
    comDate[15] = ' ';
   // Get Minutes
    tmp = RTCRegRead(0x01);
    time[10] = (tmp & 0x0F) + 0x30;
    time[9] = (tmp >> 4) + 0x30;
    // Get Hours
    tmp = RTCRegRead(0x02);
    time[7] = (tmp & 0x0F) + 0x30;
    time[6] = ((tmp >> 4) & 0x01 ) + 0x30;
    // GET AM or PM (already read register 0x02)
    time[12] = ((tmp >> 4) & 0x01 ) + 0x30;
    if(time[12] == 0){
        time[12]='A';
    } else {
        time[12]='P';
    //Get Month
    tmp = RTCRegRead(0x05);
    comDate[6] = (tmp >> 4) + 0x30 ;
    comDate[7] = (tmp & 0x0F) + 0x30 ;
    //Get Date(day)
    tmp = RTCRegRead(0x04);
    comDate[9] = (tmp >> 4) + 0x30 ;
    comDate[10] = (tmp & 0x0F) + 0x30 ;
    //Get Year
    tmp = RTCRegRead(0x06);
    comDate[12] = (tmp >> 4) + 0x30 ;
    comDate[13] = (tmp & 0x0F) + 0x30 ;
	lcd_line(2);
	lcd_string(time);
	lcd_line(1);
    if(view == 0){
	    lcd_string(string);
    } else {
    decMonth = bcd2dec(RTCRegRead(0x05), 2);
    decDate  = bcd2dec(RTCRegRead(0x04), 0);
    decYear  = bcd2dec(RTCRegRead(0x06), 0);
    decHour  = bcd2dec(RTCRegRead(0x02),1);
    decMin   = bcd2dec(RTCRegRead(0x01),3);
    decAPM   = bcd2dec(RTCRegRead(0x05),0);
    decAPM   = (decAPM >> 4) & 0x01;
            Show Menu
            Set the Time
            Set the Date
            Interrupt Code
Hey Jason,
I hope you don't think I was criticizing your code. I just wanted to give you another perspective. If anything, your progress this last year makes me think you're some kind of a savant or prodigy (grin).
Take care.
Mike
Thanks alot you guys are making me feel proud. Ill try to keep up the good work. Im sorry i havent been on in a while. 2 days ago at night i caught a tooth infection(too many sweets) and i had the tooth pulled yesterday and also caught a fever yesterday and felt like i was dieing. Today i feel a little better. Still have small pain in tooth. I dont want to eat since it hurts so i guess i gotta take it slow today as to not drain myself.
Ill be working on the clock today for sure since there isnt alot to do. Mainly just set date/time/alarm which since ive done it a few times already it doesnt seem to hard.
