circuit ideas for boosting loudspeaker output
geoff2004
Hi i need to boost the sound output from a circuit powerd by a 9v bettery ac. ive thought about using op-amps but i dont know which basic op-amp circuit to use inverting, non inverting etc ? or using a number a transistors to boost it. My understanding of electronics is not brillant and any help would be very helpful.
Many thanks Geoff b
You need to post more details?. What is the existing device?, and why do you want it louder?.
You can only get a certain amount (fairly small - about 1W into 8 ohms), off a 9V supply - if you're already getting that you would probably need to increase your supply to make it louder (using a larger amplifier and speaker). If the existing system isn't being driven enough, you could add a pre-amplifier to drive the amplifier harder - but this will still only achieve fairly low power off 9V.
But please give more details.
Battery life is another thing to consider - more power out requires more power in. Another consideration - there is a limit to the amount of current (amps) you can draw from a given battery even if short life is acceptable. Keeping efficiency up will help with battery life.
audio boost
its directly from an output tone circuit which im am also constructing. i need the circuit just to give enough sound output to be heard around 600-800 HZ. i might also use cut filters.
thanks for any help
Geoff b
A rather common IC for low power audio applications here in the US is an LM386. Sometimes they are preceeded by a 741 op amp. The National Semiconductor datasheet for the LM386 has some good application notes.
