can anybody care to explain the codes below in detail?
step by step...
coz it confuses me with basic uart sending and receiving programs... thanks...
step by step...
* where c:\mcc18 is the directory in which the compiler is installed.
* This sample application is designed for use with the MPLAB ICD2, the
* PICDEM 2 Plus demo board, and the PIC18F452 device. This sample covers the
* following items:
* 1. Creating large data objects
* 2. Reading from and writing to the USART.
* 3. Interrupt handling (#pragma interrupt, interrupt vectors, and
* interrupt service routines)
* 4. System header files
* 5. Processor-specific header files
* 6. #pragma sectiontype
* 7. Inline assembly
#include <p18f452.h>
#include <usart.h>
void rx_handler (void);
#define BUF_SIZE 25
* Step #1 The data is allocated into its own section.
#pragma idata bigdata
char data[5][BUF_SIZE+1] = {
{ "String #0\n\r" },
{ "String #1\n\r" },
{ "String #2\n\r" },
{ "String #3\n\r" },
{ "Invalid key (0-3 only)\n\r" }};
#pragma idata
#pragma code rx_interrupt = 0x8
void rx_int (void)
_asm goto rx_handler _endasm
#pragma code
#pragma interrupt rx_handler
unsigned char c;
/* Get the character received from the USART */
c = ReadUSART();
if (c >= '0' && c <= '3')
c -= '0';
/* Display value received on LEDs */
PORTB = c;
* Step #2 This example did not need an additional
* pointer to access the large memory because of the
* multi-dimension array.
* Display the string located at the array offset
* of the character received
putsUSART (data[c]);// writes string of character from data[c]
else
* Invalid character received from USART.
* Display error string.
putsUSART (data[5]);
PORTB = c;
/* Clear the interrupt flag */
PIR1bits.RCIF = 0;
void main (void)
/* Configure all PORTB pins for output */
TRISB = 0;
* Open the USART configured as
* 8N1, 2400 baud, in polled mode
OpenUSART (USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH, 103);
/* Display a prompt to the USART */
putrsUSART (
(const far rom char *)"\n\rEnter a digit 0-9!\n\r");
/* Enable interrupt priority */
RCONbits.IPEN = 1;
/* Make receive interrupt high priority */
IPR1bits.RCIP = 1;
/* Enable all high priority interrupts */
INTCONbits.GIEH = 1;
/* Loop forever */
while (1)
