Can someone explain this?
Pommie
Most Helpful Member
I know there's got to be a simple explanation but I can't see it,
I thought all these would be the same, I'm trying to put 51 in the highest byte of work.
uint32_t work;
  work=51*(2^24);
  work=51<<24;
  work=51;
  work<<=24;
but when the result is printed out, I get,
1326
0
855638016
The actual code,
uint32_t work;
void setup(){
  Serial.begin(115200);
  work=51*(2^24);
  Serial.println(work);
  work=51<<24;
  work=51;
  work<<=24;
void loop(){
What am I missing?
Thanks,
Try using 51L to force a long constant?
Any intermediate math may be done as integer, otherwise.
Yup, that fixed it except for the first one, even doing,
work=51L*(2L^24L);
And all other combos,
Doesn't fix it - answer is 1326!!!!
And also for,
work=(2L^24);
and
work=(2^24);
It appears that the compiler is taking ^ as +.
Just tried,
work=(2^20);
and it gives 22!!!
Looks like a compiler bug!
It explains the 1326 result, at least.
Does the same thing happen with small powers, eg. 2^3 ?
