Car battery charger
Xikluna
Can anyone pls supply me with pdf of article for car battery charger found in Electronics Today International, year 1973, month November, page 64. I lost the magazine in question. Thanks
Why do you want to use a circuit that is 45 years old?
I would think there are modern designs that are better.
That car battrry charger has been working ever since without any fault. The circuit is very simple yet highly efficient. I have charged totally dead batteries and i wouldnt change it for another car battery chatger. It is very important for me to find the said article. If i am so unfortunate i would apprrciate if you send ma a good circuit for a car battery charger which i can build cause i need one urgently. Tks for your kind interest.
If you trace out the schematic of your faulty charger and post it here there is a good chance that we can help you fix the fault.
Les.
There is a web site with archives of old electronics magazines, but unfortunately that particular issue is not in their collection..
https://www.americanradiohistory.com/ETI_Magazine.htm
This looks to be a good straightforward charger with two-level charge, automatic bulk / trickle modes:
(Though I think they mean calibrate is at 25'C not 250'C ...)
Tks for all your help and interest.
Tks for tbr circuit also.
The most important issue of my charger is that it uses pulse width modulated voltage to trickle charge the battery when fully charged. A very important feature.
I ll start testing transistors, diodes triac to begin with.. See you guys. Tks
I think I remember that circuit - I built one, when the article first came out, though I was using it for NiCd batteries..
Something like a thyristor and simple voltage comparator??
Here's an efficient PWM switcher battery charging circuit that may be of interest to you.
A very good charging circuit although a little bit complicated. Tks for your help. I'll take a good look at it. Tks
Perhaps, but I doubt you will find anything significantly simpler that does a 3-step lead-acid battery charge using PWM.
You are right. Problem is i need one now. That's why i'm trying to fix mine. Or else i have to buy one. Maybe if i find the appropriate circuit i'll build another one. At the moment i'm trying to service mine without a schematic. Thanks for everything.
Quite difficult because the cct is not built on pcb. At the moment i'm checking components and voltages. Tks
It is electronics today international, magazine. Unfortunately i need November 1973 edition, which is missing from the list.
Tks just the same. I appreciate.
Electronics Today International was a Canadian hobbyist publication, and won't be on that list. I had those issues from December 1979 to March 1985, gone since October 2015. None of my issues had PWM circuits in them, just simple elementary circuits.
