capture module with lcd
lakis
Hi guys , I am trying to measures the period and the high time of rectangular waveform using capture mode and display them on a 2x16 lcd . I am using ccp1 as input .
But although the program is build succeeded the screen doesn’t display anything .
I am working with pic18f452 and pic18f4520 I use mplap ide v8.63 and c18 lite v3,36.
The period of the waveform can be adjusted between 1,5ms and 3ms and it is between 3 and 5 volts .
This is the code I’m working on .
 #include "p18f452.h"// Include files and definitions for the Processor
#include<xlcd.h>// Include function definitions for the External LCD Library library
#include<delays.h>// Include function definitions for built in Delay routines
#include <stdio.h>
#include <timers.h>
#include<stdlib.h>// Include function definitions for string manupulation Library
#include<capture.h>//Include function definitions for the Capture library
//#include <stdlib.h> /**********tin aferesa epeidi ekane problima sto itoa. Kanonika auti einai bibliothiki poy exei to idoa mesa tin ebala otan ebla ton ADC kodika Den ipirxe prin. Douleue sosta xvris ayti*/
#pragma config LVP=OFF
#pragma config OSC=HS
#pragma config WDT=OFF// Use internal Oscillator, Watchdog off, LVP off
#pragma config DEBUG = ON
unsigned int result,hightime,totaltime,dutycycle;//Variables used
unsigned char start=1;
unsigned char highlow,end;
 unsigned char data[]="Thigh";
unsigned char data1[]="totaltime";
char str1[5];
char str2[5];
void DelaySTRING(void);
void Send(void);// Function for sending data to serial port
void chk_isr(void);// ISR Handler
void hi_prioriint(void)// ISR Routine
                _asm
                GOTO chk_isr
                _endasm
#pragma interrupt chk_isr
void chk_isr(void)
                if(PIR1bits.CCP1IF)
                                                if(start==1)
        WriteTimer1(00);//Start timer 1 for maximum count
        OpenCapture1( CAPTURE_INT_ON & //Initialize CCP for HtoL
        C1_EVERY_FALL_EDGE );
        start=0;
        highlow=1;
        PIR1bits.CCP1IF=0;// Enable interrupt again
                                                else
        if(highlow==1)
        hightime = ReadCapture1();// Read contents of capture registers
        OpenCapture1( CAPTURE_INT_ON & //Initialize CCP for LtoH
        C1_EVERY_RISE_EDGE );
        highlow=0;
        end=1;
        PIR1bits.CCP1IF=0;
        else
        if(end==1)
        totaltime=ReadCapture1();// Read contents of Capture registers
        CloseTimer1();// Close timer 1
        Send();// Send the measured time values to the serial port
void main(void)
               // OSCCON=0x60;//Internal 4MHz oscillator
                ADCON1=0x7f;//Make all  pins Digital
                //Initiazlize the capture moudule(ccp) for LtoH
                OpenCapture1( C1_EVERY_RISE_EDGE
        & CAPTURE_INT_ON  );
                OpenTimer1( TIMER_INT_OFF &//configure Timer1 for ccp
        T1_16BIT_RW &// Can also use Timer3
        T1_SOURCE_INT & // Timer1 clock source is internal
        T1_SOURCE_CCP &// Make Timer1 source for CCP module
        T1_PS_1_1);// No prescaler for timer1
                                                  INTCONbits.PEIE=1;// Enable peripheral interrupts
                                                   INTCONbits.GIEH=1;// Enable all interrupts
                while(1);// wait here
void Send(void)// For sending the times
              OpenXLCD( EIGHT_BIT & LINES_5X7 );// Use 8 bit Data, 5x7 pixel Matrix per character
              while( BusyXLCD());// Wait till LCD finishes executing command
              WriteCmdXLCD( CURSOR_ON);// Turn cursor ON
               while( BusyXLCD() );// Wait till LCD finishes executing command
              WriteCmdXLCD( 0x80);// Force curson to the begining of 1st line
                WriteCmdXLCD( SHIFT_DISP_LEFT );//Shift Cursor Display Left
                  putsXLCD(data);// Write the String data to the LCD
                  WriteCmdXLCD( 0xC0);// Force curson to the begining of 2nd line
   ultoa(hightime,str1);// convert integer in to string
                  putsXLCD(str1);
                  while( BusyXLCD());
                  WriteCmdXLCD(0b00000001);// Clear Display
  ultoa(totaltime,str2);// convert integer in to string
                   putsXLCD(str2);
                CloseCapture1();// Close CCP Module
                INTCONbits.GIE=0;//Disbale interrupts
void DelayFor18TCY(void)
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
void DelayPORXLCD(void)
Delay1KTCYx(75);
void DelayXLCD(void)
Delay1KTCYx(25);
Delay10KTCYx(456);//450//1562
  //the  cature part of the code was add by wonderboy in an other thread
I know this subject is been discussed again but I am stuck here for more than two weeks and I have try anything I can think. i have add the diagram of my circuit
I have some sample code, I'm afraid its for avr studio, but you can change it to suit your need.
4 bit lcd
interface
void lcd_init()	// fuction for intialize
	dis_cmd(0x02);		// to initialize LCD in 4-bit mode.
	dis_cmd(0x28);		//to initialize LCD in 2 lines, 5X7 dots and 4bit mode.
	dis_cmd(0x0C);
	dis_cmd(0x06);
	dis_cmd(0x80);
	_delay_ms(100);
void dis_cmd(char cmd_value)
	char cmd_value1;
	cmd_value1 = cmd_value & 0xF0;		//mask lower nibble because PA4-PA7 pins are used.
	lcdcmd(cmd_value1);			// send to LCD
 	cmd_value1 = ((cmd_value<<4) & 0xF0);	//shift 4-bit and mask
void to_line(char line,char pos)
if(line ==1)
 	dis_cmd(0x80 + pos);
else
 	dis_cmd(0xC0+pos);
void clear()
    to_line(1,0);
    lcd_write_string("                ");
void dis_data(char data_value)
	char data_value1;
	data_value1=data_value&0xF0;
	lcddata(data_value1);
	data_value1=((data_value<<4)&0xF0);
void lcdcmd(char cmdout)
	ctrl=cmdout;
	ctrl&=~(1<<rs);
	ctrl|=(1<<en);
	_delay_ms(1);
	ctrl&=~(1<<en);
void lcddata(char dataout)
	ctrl=dataout;
	ctrl|=(1<<rs);
	ctrl|=(1<<en);
	_delay_ms(1);
	ctrl&=~(1<<en);
void lcd_write_string(char *str)	//take address vaue of the string in pionter *str
	int i=0;
	while(str[i]!='\0')				// loop will go on till the NULL charaters is soon in string
		dis_data(str[i]);				// sending data on CD byte by byte
		i++;
//convert the values .. eg: convert(1000,3);
void convert(unsigned int value,unsigned int numb)
unsigned char text[numb];
unsigned char t,temp_char;
 for(t=1;t<=numb;t++)
   temp_char = value%10;
   value=value/10;
   text[t]=temp_char+48;
 for(t=numb;t>=1;t--)
  dis_data(text[t]);//=text[t];
Firstly... You can't use OpenXLCD(); twice.... This should be once in the main routine... before while(1);
Secondly... The XLCD header is set up for 4 bit interface on PORTB... You need to change this...
Ian Rogers thanks for the answer i will move openXlcd the main .I think i have set ok the xlcd.h as for the program <magvitron> add i will try to understand and changed it but I'm not sure if i can
  • xlcd.h
i try to modify my program but steel the screen doesn't display anything not even the words
<<this is thigh>>
If i program pic18f452 just to display some small phrases it works fine but now i can just see cursor in the begging of first line.
this is my code now :
#include <stdio.h>
#include <timers.h>
//#include<stdlib.h>// Include function definitions for string manupulation Library
#define DATALCD PORTD
#define dirDATA TRISD
 unsigned char data[]="this is Thigh";
char str1[5];
char str2[5];
unsigned char newlineadd=0x40;
void LCDdata (unsigned char);
void LCDDelay( void );
void lcdcmd(unsigned char);
void stringtoLCD(unsigned char *m);
unsigned char * itoa(unsigned int value  , unsigned char * string);//
unsigned char dataString[10];
unsigned char *biginin;
                _asm
                GOTO chk_isr
                _endasm
void chk_isr(void)
                if(PIR1bits.CCP1IF)
                                                if(start==1)
        start=0;
        highlow=1;
                                                else
        if(highlow==1)
        highlow=0;
        end=1;
        PIR1bits.CCP1IF=0;
        else
        if(end==1)
void main(void)
        & CAPTURE_INT_ON  );
int integer,i,k,t,z;//????
            biginin=&dataString[0];
              WriteCmdXLCD( 0x80);// Force curson to the begining of 2nd line
 DelaySTRING();
					integer=hightime;
					DelaySTRING();
					LCDDelay();
					itoa (integer, biginin);
					WriteCmdXLCD( 0xC0);          //Emfanizontai sti 2 grammi
					stringtoLCD(dataString);
                  while( BusyXLCD());
DelaySTRING();
                   DelaySTRING();
					integer=totaltime;
					DelaySTRING();
					LCDDelay();
					ultoa (integer, biginin);
					WriteCmdXLCD( 0xCA);          //Emfanizontai sti 2 grammi
void LCDdata (unsigned char value)
BusyXLCD();//busylcd();
TRISD = 0;
DATALCD = value;
RS_PIN=1;
RW_PIN=0;
E_PIN=1;
LCDDelay();
E_PIN=0;
void LCDDelay(void)
int i=0;
for (i=0;i<250;i++);
i think  i have added   all the source file  that  the c18  functions need  to work.(cp1close,cp1open, cp1read,t1open,t1write)  and for lcd ( wcmdxlcd,putsxlcd,openxlcd,busyxlcd)
please help me .
Thank you.
unsigned char i;
i = 0;
while(m[i] != 0)
LCDdata(m[i]);
i++;
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
_asm NOP _endasm
Delay1KTCYx(15);
Delay1KTCYx(5);
//Delay1KTCYx(450);   // Stin pragmatikotita MONO
	Delay1KTCYx(100);//Gia prosomoiosi MONO
please help me .
Thank you.
I don't have time to check your code but I suspect your interrupt as you don't specify an address. See example 6 & 7 in this document for more details. Also, your comment states internal osc but your config is for a crystal.
my circuit have 20MHz crystal oscillator connected on osc1 ,osc2 should i set the timer 1 as external source?
Hi guys. I finally managed measure and display on the 2x16 LCD the period and Thigh time of rectangular waveform.
My problem now is that duty cycle doesn’t display on screen .
The duty cycle (DC=thigh/Total ) is a decimal number . This is code
 float dutycycles;
char buffer[8];
WriteCmdXLCD(0x80); // Force curson to the begining of 1st line
ftoa(dutycycles,4,buffer);
    	putsXLCD(buffer);
but i get
Error - could not find definition of symbol 'ftoa' in file './titl.o'.
i have also try itoa () but still nothing
please help
