Cant display to lcd in assembly for PIC16F877A
kvothe666
Trying to write simple taxi meter program to simulate in proteus isis, can see lots of activity on the port connected to the lcd, but no characters come up at all, an ideas???
also i used the lcd modules from Nigel's tutorial 3.2, so should work... (http://www.winpicprog.co.uk)
	LIST	p=16F877A		;tell assembler what chip we are using
	include "P16F877A.inc"		;include the defaults for the chip
		cblock	0x20			;start of general purpose registers
			count			;used in looping routines
			count1			;used in delay routine
			counta			;used in delay routine
			countb			;used in delay routine
			tmp1			;temporary storage
			tmp2
			templcd			;temp store for 4 bit mode
			templcd2
        		NumL			;Binary inputs for decimal convert routine
	        	NumH
        		TenK			;Decimal outputs from convert routine
	        	Thou
        		Hund
	        	Tens
        		Ones
		DorF			;distance or fare
		Dist1
		Dist2
		Fare1
		Fare2
		endc
LCD_PORT	Equ	PORTC
LCD_TRIS	Equ	TRISC
LCD_RS		Equ	0x04			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
		org	0x0000
		goto	Initialise
		org	0x0004
		goto	Distance
Initialise		clrf	count
		clrf	PORTA
		clrf	PORTB
		clrf	NumL
		clrf	NumH
		bsf	INTCON, GIE	; enables global interrupt
		bsf	INTCON, INTE	; enables the interrupt on portb[0]
SetPorts	bsf 	STATUS,		RP0	;select bank 1
		movlw	0x00			;make all pins outputs
		movwf	LCD_TRIS
		bcf 	STATUS,		RP0	;select bank 0
		call	LCD_Init		;setup LCD
wait		nop
		goto	wait
Distance
		call	LCD_Line1		;move to 1st row, 1st column
		movlw	'D'
		call	LCD_Char
		movlw	'i'
		call	LCD_Char
		movlw	's'
		call	LCD_Char
		movlw	't'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'n'
		call	LCD_Char
		movlw	'c'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		bcf	DorF,0
		call	Convert
		movf	TenK, w
		call	LCD_CharD
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'M'
		call	LCD_Char
Fare
		call	LCD_Line2		;move to 2nd row, 1st column
		movlw	'F'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'r'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		movlw	'£'
		call	LCD_Char
		bsf	DorF,0
		call	Convert
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'.'
		call	LCD_Char
		movf	Ones, w
		call	LCD_CharD
		incfsz	NumL, f
		goto	Next
		incf	NumH, f
Next
		retfie
		goto wait
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init	call	Delay100		;wait for LCD to settle
		movlw	0x20			;Set 4 bit mode
		call	LCD_Cmd
		movlw	0x28			;Set display shift
		call	LCD_Cmd
		movlw	0x06			;Set display character mode
		call	LCD_Cmd
		movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd			;Set cursor off
		call	LCD_Clr			;clear display
		retlw	0x00
; command set routine
LCD_Cmd		movwf	templcd
		swapf	templcd,	w	;send upper nibble
		andlw	0x0f			;clear upper 4 bits of W
		movwf	LCD_PORT
		bcf	LCD_PORT, LCD_RS	;RS line to 1
		call	Pulse_e			;Pulse the E line high
		movf	templcd,	w	;send lower nibble
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_CharD	addlw	0x30			;add 0x30 to convert to ASCII
LCD_Char	movwf	templcd
		movwf	LCD_PORT
		bsf	LCD_PORT, LCD_RS	;RS line to 1
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_Line1	movlw	0x80			;move to 1st row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line2	movlw	0xc0			;move to 2nd row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line1W	addlw	0x80			;move to 1st row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_Line2W	addlw	0xc0			;move to 2nd row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_CurOn	movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_CurOff	movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_Clr		movlw	0x01			;Clear display
		call	LCD_Cmd
		retlw	0x00
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (4 MHz clock)
d0		movwf	count1
d1		movlw	0xC7			;delay 1mS
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
Pulse_e		bsf	LCD_PORT, LCD_E
		nop
		bcf	LCD_PORT, LCD_E
		retlw	0x00
;end of LCD routines
;This routine downloaded from http://www.piclist.com
Convert:                        ; Takes number in NumH:NumL
                                ; Returns decimal in
                                ; TenK:Thou:Hund:Tens:Ones
        swapf   NumH, w
	iorlw	B'11110000'
        movwf   Thou
        addwf   Thou,f
        addlw   0XE2
        movwf   Hund
        addlw   0X32
        movwf   Ones
        movf    NumH,w
        andlw   0X0F
        addwf   Hund,f
        addwf   Hund,f
        addwf   Ones,f
        addlw   0XE9
        movwf   Tens
        addwf   Tens,f
        addwf   Tens,f
        swapf   NumL,w
        andlw   0X0F
        addwf   Tens,f
        addwf   Ones,f
        rlf     Tens,f
        rlf     Ones,f
        comf    Ones,f
        rlf     Ones,f
        movf    NumL,w
        andlw   0X0F
        addwf   Ones,f
        rlf     Thou,f
        movlw   0X07
        movwf   TenK
                    ; At this point, the original number is
                    ; equal to
                    ; TenK*10000+Thou*1000+Hund*100+Tens*10+Ones
                    ; if those entities are regarded as two's
                    ; complement binary.  To be precise, all of
                    ; them are negative except TenK.  Now the number
                    ; needs to be normalized, but this can all be
                    ; done with simple byte arithmetic.
        movlw   0X0A                             ; Ten
Lb1:
        addwf   Ones,f
        decf    Tens,f
        btfss   3,0
        goto   Lb1
Lb2:
        addwf   Tens,f
        decf    Hund,f
        btfss   3,0
        goto   Lb2
Lb3:
        addwf   Hund,f
        decf    Thou,f
        btfss   3,0
        goto   Lb3
Lb4:
        addwf   Thou,f
        decf    TenK,f
        btfss   3,0
        goto   Lb4
        retlw	0x00
		end
just reassigned to portb pin 6, although now i realise that lcd_rw is declared bu isnt used in the code, although confused why this is?
pin is 0 and im using delays instead of the busy flag, when i step through the program it gets to the LCD_INIT routine and doesnt come out of it, with continuous data being sent over portc, but nothing seen on the lcd
thanks.
okay after testing, its whenever the interrupt is triggered that it goes into the loop, however the code below should send letters to the display before the interrupt is triggered, but nothing is seen.
			tmp2
			templcd2
	        	NumH
	        	Thou
        		Hund
	        	Tens
        		Ones
		Dist1
		Dist2
		Fare1
		Fare2
		endc
LCD_PORT	Equ	PORTC
LCD_TRIS	Equ	TRISC
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
		org	0x0000
		goto	Initialise
		org	0x0004
		goto	Distance
		clrf	PORTA
		clrf	PORTB
		clrf	NumL
		clrf	NumH
		movlw	0x07
		movwf	CMCON			;turn comparators off (make it like a 16F84)
		movwf	LCD_TRIS
		movlw	'D'
		call	LCD_Char
		movlw	'i'
		call	LCD_Char
		movlw	's'
		call	LCD_Char
		movlw	't'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'n'
		call	LCD_Char
		movlw	'c'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		movlw	'F'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'r'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		movlw	'£'
		call	LCD_Char
wait		nop
		goto	wait
Distance		movlw	d'10'
		call	LCD_Line1W
		bcf	DorF,0
		call	Convert
		movf	TenK, w
		call	LCD_CharD
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'M'
		call	LCD_Char
Fare		movlw	d'05'
		call	LCD_Line2W
		bsf	DorF,0
		call	Convert
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'.'
		call	LCD_Char
		movf	Ones, w
		call	LCD_CharD
		incfsz	NumL, f
		goto	Next
		incf	NumH, f
Next
		retfie
;LCD routines
;Initialise LCD
		call	LCD_Cmd
		call	LCD_Cmd
		call	LCD_Cmd
		return
		movwf	LCD_PORT
		movwf	LCD_PORT
		call 	Delay5
		return
		movwf	LCD_PORT
		movwf	LCD_PORT
		call 	Delay5
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		goto	d0
		goto	d0
		goto	d0
		goto	d0
d0		movwf	count1
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		return
		nop
		bcf	LCD_PORT, LCD_E
		return
        swapf   NumH, w
	iorlw	B'11110000'
        movwf   Thou
        addwf   Thou,f
        addlw   0XE2
        movwf   Hund
        addlw   0X32
        movwf   Ones
        movf    NumH,w
        andlw   0X0F
        addwf   Hund,f
        addwf   Hund,f
        addwf   Ones,f
        addlw   0XE9
        movwf   Tens
        addwf   Tens,f
        addwf   Tens,f
        swapf   NumL,w
        andlw   0X0F
        addwf   Tens,f
        addwf   Ones,f
        rlf     Tens,f
        rlf     Ones,f
        comf    Ones,f
        rlf     Ones,f
        movf    NumL,w
        andlw   0X0F
        addwf   Ones,f
        rlf     Thou,f
        movlw   0X07
        movwf   TenK
                    ; equal to
        movlw   0X0A                             ; Ten
Lb1:
        addwf   Ones,f
        decf    Tens,f
        btfss   3,0
        goto   Lb1
Lb2:
        addwf   Tens,f
        decf    Hund,f
        btfss   3,0
        goto   Lb2
Lb3:
        addwf   Hund,f
        decf    Thou,f
        btfss   3,0
        goto   Lb3
Lb4:
        addwf   Thou,f
        decf    TenK,f
        btfss   3,0
        goto   Lb4
        return
		end
works fine.. I've changed the LCD init a bit
Also put the global interrupt enable AFTER the lcd init and first lines
			tmp2
			templcd2
	        	NumH
	        	Thou
        		Hund
	        	Tens
        		Ones
		Dist1
		Dist2
		Fare1
		Fare2
		endc
LCD_PORT	Equ	PORTC
LCD_TRIS	Equ	TRISC
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
		org	0x0000
		goto	Initialise
		org	0x0004
		goto	Distance
		clrf	PORTA
		clrf	PORTB
		clrf	NumL
		clrf	NumH
		movlw	0x07
		movwf	LCD_TRIS
		movlw	'D'
		call	LCD_Char
		movlw	'i'
		call	LCD_Char
		movlw	's'
		call	LCD_Char
		movlw	't'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'n'
		call	LCD_Char
		movlw	'c'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		movlw	'F'
		call	LCD_Char
		movlw	'a'
		call	LCD_Char
		movlw	'r'
		call	LCD_Char
		movlw	'e'
		call	LCD_Char
		movlw	':'
		call	LCD_Char
		movlw	' '
		call	LCD_Char
		movlw	'£'
		call	LCD_Char
wait		nop
		goto	wait
		call	LCD_Line1W
		bcf	DorF,0
		call	Convert
		movf	TenK, w
		call	LCD_CharD
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'M'
		call	LCD_Char
Fare		movlw	d'05'
		call	LCD_Line2W
		bsf	DorF,0
		call	Convert
		movf	Thou, w
		call	LCD_CharD
		movf	Hund, w
		call	LCD_CharD
		movf	Tens, w
		call	LCD_CharD
		movlw	'.'
		call	LCD_Char
		movf	Ones, w
		call	LCD_CharD
		incfsz	NumL, f
		goto	Next
		incf	NumH, f
Next
		retfie
;LCD routines
;Initialise LCD
		movlw	0x3
		movwf	PORTC
		bsf	PORTC,7
		bcf	PORTC,7
 		call	Delay50
		movlw	0x2
		movwf	PORTC
		bsf	PORTC,7
		bcf	PORTC,7
 		call	Delay50
		call	LCD_Cmd
		call	LCD_Cmd
		call	LCD_Cmd
		return
		movwf	LCD_PORT
		movwf	LCD_PORT
		call 	Delay5
		return
		movwf	LCD_PORT
		movwf	LCD_PORT
		call 	Delay5
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		call	LCD_Cmd
		return
		goto	d0
		goto	d0
		goto	d0
		goto	d0
d0		movwf	count1
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		return
		nop
		bcf	LCD_PORT, LCD_E
		return
        swapf   NumH, w
	iorlw	B'11110000'
        movwf   Thou
        addwf   Thou,f
        addlw   0XE2
        movwf   Hund
        addlw   0X32
        movwf   Ones
        movf    NumH,w
        andlw   0X0F
        addwf   Hund,f
        addwf   Hund,f
        addwf   Ones,f
        addlw   0XE9
        movwf   Tens
        addwf   Tens,f
        addwf   Tens,f
        swapf   NumL,w
        andlw   0X0F
        addwf   Tens,f
        addwf   Ones,f
        rlf     Tens,f
        rlf     Ones,f
        comf    Ones,f
        rlf     Ones,f
        movf    NumL,w
        andlw   0X0F
        addwf   Ones,f
        rlf     Thou,f
        movlw   0X07
        movwf   TenK
                    ; equal to
        movlw   0X0A                             ; Ten
Lb1:
        addwf   Ones,f
        decf    Tens,f
        btfss   3,0
        goto   Lb1
Lb2:
        addwf   Tens,f
        decf    Hund,f
        btfss   3,0
        goto   Lb2
Lb3:
        addwf   Hund,f
        decf    Thou,f
        btfss   3,0
        goto   Lb3
Lb4:
        addwf   Thou,f
        decf    TenK,f
        btfss   3,0
        goto   Lb4
        return
		end
