CAN bus and isis proteus
massaab
hello everybody,
my project is to establish communication between pic18F and other devices using CAN bus, i wrote my code with mikroC but the problem i can't find the MCP2551 Transceiver and MCP2510 Controller in isis proteus for simulation.
it's possible to add a MCP2551,MCP2510 library to proteus ?
i can't find any library in the web !!
thanks a lot :)
thank you sir ,
so i must buy the composants and doing a real simulation ?
or i can find other logiciel for simulation ?
thank u :)
Contradiction in terms.... Can from mpu to mpu is basically hardware.. Without the line drivers you can hook up pin to pin for sim purposes and use a different protocol.. Write a "sim only " function that takes the can parameters and pretend the hardware is all good!! What compiler are you going to use?
