By replicate, do you mean build one from scratch? Or adapt a PCB accelerometer/gyro PCB to control a servo?
Gyro (aka accelerometer) controls are standard fare in many models, particularly in aircraft and helicopters with one or more rotors. One option is to buy a complete model and scavenge the gyro and servo circit. Alternatively, you can buy the gyro chip already designed to operate a servo. Finally, you can buy the bare chips fairly cheaply and build your own circuit. You will need a microcontroller and be able to program it to do this last approach.
Please let us know more about your project and how you want to approach it.
John
This is specifically for rc sub work so the plentiful (and cheap) modules out there for Airplanes will not work.
I mean adapt a existing module to do this...they HAVE to be less expensive than existing modules that approach $100.00 or more
Basic info on how RC Sub Autolevellers work in comparison to RC Airplane ones:
The Auto leveler will work the stern planes to keep the boat level when no input from the transmitter is received. When you apply input to your transmitter, the receiver will act on that input overriding the auto leveler for the most part.
Same with airplanes.The auto leveler will return the boat to level when you release the tx input.
Again no difference between a sub and an airplane when the sub is about neutral buoyancy. Now, if the sub takes on water to dive, there in no comparable mechanism for airplanes to add water or mass while in flight (excluding in flight refuelingTo dive and rise a submarine requires very little input, the auto leveler trying to counter act the tx input is not enough so the input to the planes will be more than the auto leveler.
Im not certain why, other than the aforementioned explanations, but many people "in the know" state that Airplane units cannot be used in submarines. Subs don't ALWAYS take on water to dive, often they are forced under water by the speed of the sub as well as the angle of their rear dive planes (where autolevellers are used). Front planes are used for stabilization onlyHow is that different than an accelerometer on an airplane stabilizer/stabilator/elevator?
Again no difference between a sub and an airplane when the sub is about neutral buoyancy. Now, if the sub takes on water to dive, there in no comparable mechanism for airplanes to add water or mass while in flight (excluding in flight refueling). However, some aircraft (e.g., sailplanes) routinely carry water ballast, which they can jettison to control their flight characteristics.
An accelerometer controlling a servo to maintain or change a control axis is no different in a sub than in an airplane. You may be confusing gyros that have a rotating wheel with modern accelerometers. Some use a vibrating weight, and others have no moving mechanical parts at all. They do not have to be reset periodically to a horizon.
John
My airplane has a rubber band.My rc airplanes have elevator, rudder and aileron accelerometers
My last one is on the other side of the golf course....... Somewhere.My airplane has a rubber band.
My last one is on the other side of the golf course....... Somewhere.![]()
