; Software License Agreement
; The software supplied herewith by Microchip Technology
; Incorporated (the “Company”) for its PICmicro® Microcontroller is
; intended and supplied to you, the Company’s customer, for use
; solely and exclusively on Microchip PICmicro Microcontroller
; products. The software is owned by the Company and/or its
; supplier, and is protected under applicable copyright laws. All
; rights are reserved. Any use in violation of the foregoing
; restrictions may subject the user to criminal sanctions under
; applicable laws, as well as to civil liability for the breach of
; the terms and conditions of this license.
; THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES,
; WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
; TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
; PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
; IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
; CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
; Bootloader for PIC18F by Ross Fosler
; 09/1/2006 Modified to support PIC18xxJxx & 160k PIC18Fxxx Flash Devices
; 03/01/2002 ... First full implementation
; 03/07/2002 Changed entry method to use last byte of EEDATA.
; Also removed all possible infinite loops w/ clrwdt.
; 03/07/2002 Added code for direct boot entry. I.E. boot vector.
; 03/09/2002 Changed the general packet format, removed the LEN field.
; 03/09/2002 Modified the erase command to do multiple row erase.
; 03/12/2002 Fixed write problem to CONFIG area. Write was offset by a byte.
; 03/15/2002 Added work around for 18F8720 tblwt*+ problem.
; 03/20/2002 Modified receive & parse engine to vector to autobaud on a checksum
; error since a chechsum error could likely be a communications problem.
; 03/22/2002 Removed clrwdt from the startup. This instruction affects the TO and
; PD flags. Removing this instruction should have no affect on code
; operation since the wdt is cleared on a reset and boot entry is always
; on a reset.
; 03/22/2002 Modified the protocol to incorporate the autobaud as part of the
; first received <STX>. Doing this improves robustness by allowing
; re-sync under any condition. Previously it was possible to enter a
; state where only a hard reset would allow re-syncing.
; 03/27/2002 Removed the boot vector and related code. This could lead to customer
; issues. There is a very minute probability that errent code execution
; could jump into the boot area and cause artificial boot entry.
; Memory Map
; | 0x0000 |
; | 0x0002 | Boot vector
; | 0x0004 | Unlock & write vector
; | Boot Block | (this program)
; | | (PIC18Fxxx Devices)
; | 0x0200 | Re-mapped Reset Vector
; | 0x0208 | Re-mapped High Priority Interrupt Vector
; | 0x0218 | Re-mapped Low Priority Interrupt Vector
; | | (PIC18FxxJxx Devices)
; | 0x0400 | Re-mapped Reset Vector
; | 0x0408 | Re-mapped High Priority Interrupt Vector
; | 0x0418 | Re-mapped Low Priority Interrupt Vector
; | Code Space | User program space
; | 0xXXXXXX |
; Incomming data format:
; <STX><STX><DATA><CHKSUM><ETX>
; ________/ \____________________________
; <COMMAND><DLEN><ADDRL><ADDRH><ADDRU><DATA>...
; Definitions:
; STX - Start of packet indicator
; ETX - End of packet indicator
; LEN - Length of incomming packet
; DATA - General data up to 255 bytes
; CHKSUM - The 8-bit two's compliment sum of LEN & DATA
; COMMAND - Base command
; DLEN - Length of data associated to the command
; ADDR - Address up to 24 bits
; DATA - Data (if any)
; Commands:
; RD_VER 0x00 Read Version Information
; RD_MEM 0x01 Read Program Memory
; WR_MEM 0x02 Write Program Memory
; ER_MEM 0x03 Erase Program Memory
; RD_EE 0x04 Read EEDATA Memory
; WR_EE 0x05 Write EEDATA Memory
; RD_CONFIG 0x06 Read Config Memory
; WT_CONFIG 0x07 Write Config Memory
;#include P18F452.INC ; Standard include
;#include P18F8720.inc
;#include P18F8622.inc
;#include P18f67J10.inc
;#include P18F8722.inc
;#include J_Defines.inc
;#include 64byte_Defines.inc
LIST P=18F2525
#include P18F2525.inc
CONFIG WDT = OFF, LVP = OFF, OSC = INTIO67, XINST = OFF
#define RCREG1 RCREG
#define TXREG1 TXREG
#define RCSTA1 RCSTA
#define TXSTA1 TXSTA
#define SPBRG1 SPBRG
#define ProgBtn 0
#define ProgBtnT TRISB
#define ProgBtnP PORTB
#define MINOR_VERSION 0x0C ; Version
#define MAJOR_VERSION 0x00
#define RC_DLE 0x01
#define RC_STX 0x02
#define STX 0x0F
#define ETX 0x04
#define DLE 0x05
;#define TBLWT_BUG ; Timing bug found in some PIC18Fxx20s
CHKSUM equ 0x00 ; Checksum accumulator
COUNTER equ 0x01 ; General counter
ABTIME_H equ 0x02
ABTIME_L equ 0x03
RXDATA equ 0x04
TXDATA equ 0x05
J_PACKET_COUNTER equ 0x6
; Frame Format
; <STX><STX>[<COMMAND><DATALEN><ADDRL><ADDRH><ADDRU><...DATA...>]<CHKSUM><ETX>
DATA_BUFF equ 0x08 ; Start of receive buffer
COMMAND equ 0x08 ; Data mapped in receive buffer
DATA_COUNT equ 0x09
ADDRESS_L equ 0x0A
ADDRESS_H equ 0x0B
ADDRESS_U equ 0x0C
PACKET_DATA equ 0x0D
pmwtpi macro ; tblwt*+ macro for PIC18Fxx20 bug
IFDEF TBLWT_BUG
tblwt *
tblrd *+
ELSE
tblwt *+
ENDIF
endm
ORG 0x0000 ; Re-map Reset vector
bra Setup
bra StartWrite
ORG 0x0008
VIntH
bra RVIntH ; Re-map Interrupt vector
ORG 0x0018
VIntL
bra RVIntL ; Re-map Interrupt vector
; Setup the appropriate registers.
Setup
movlw 0x72
movwf OSCCON
btfss OSCCON,IOFS
bra $-2
movlw 0x0F
movwf ADCON1
BSF ProgBtnT, ProgBtn
movlw .4
movwf J_PACKET_COUNTER
#ifdef J_FLASH
;Read a location in the last erasable row of flash program memory before the block that contains the configuration words
;0xFF = Boot Mode, 0x00 = Run Mode
movlw J_FLASH_BOOT_MODE_L
movwf TBLPTRL
movlw J_FLASH_BOOT_MODE_H
movwf TBLPTRH
movlw J_FLASH_BOOT_MODE_U
movwf TBLPTRU
tblrd *+ ; Fill buffer
incfsz TABLAT,W
bra RVReset
#else
btfss ProgBtnP, ProgBtn
bra RVReset ; If not 0xFF then normal reset
; clrf EECON1
; setf EEADR ; Point to last location
; setf EEADRH
; bsf EECON1, RD ; Read the control code
; incfsz EEDATA, W
; bra RVReset ; If not 0xFF then normal reset
#endif
bcf TRISC, 6 ; Setup tx pin
; bsf TRISC, 7 ; Setup rx pin
movlw b'10010000' ; Setup rx and tx
movwf RCSTA1
movlw b'00100110'
movwf TXSTA1
Autobaud
; ___ __________ ________
; \__/ \__________/
; |-------- p ----------|
; p = The number of instructions between the first and last
; rising edge of the RS232 control sequence 0x0F. Other
; possible control sequences are 0x01, 0x03, 0x07, 0x1F,
; 0x3F, 0x7F.
; SPBRG = (p / 32) - 1 BRGH = 1
bcf RCSTA1, CREN ; Stop receiving
movlw b'00000011' ; x16 Prescale
movwf T0CON
clrf TMR0H ; Reset timer
clrf TMR0L
rcall WaitForRise
bsf T0CON, TMR0ON ; Start counting
rcall WaitForRise
bcf T0CON, TMR0ON ; Stop counting
movff TMR0L, ABTIME_L ; Read the timer
DivB32 rrcf TMR0H, F ; divide by 2
rrcf ABTIME_L, F
btfss STATUS, C ; Rounding
decf ABTIME_L, F
movff ABTIME_L, SPBRG1 ; Sync
bsf RCSTA1, CREN ; Start receiving
movf RCREG1, W ; Empty the buffer
movf RCREG1, W
; Read and parse the data.
StartOfLine
rcall RdRS232 ; Get second <STX>
xorlw STX
bnz Autobaud ; Otherwise go back for another character
lfsr 0, DATA_BUFF ; Point to the buffer
clrf CHKSUM ; Reset checksum
clrf COUNTER ; Reset buffer count
GetNextDat
rcall RdRS232 ; Get the data
xorlw STX ; Check for a STX
bz StartOfLine ; Yes, start over
NoSTX movf RXDATA, W
xorlw ETX ; Check for a ETX
bz CheckSum ; Yes, examine checksum
NoETX movf RXDATA, W
xorlw DLE ; Check for a DLE
bnz NoDLE
rcall RdRS232 ; Yes, Get the next byte
NoDLE movf RXDATA, W
addwf CHKSUM, F ; Get sum
movwf POSTINC0 ; Store the data
dcfsnz COUNTER, F ; Limit buffer to 256 bytes
bra Autobaud
bra GetNextDat
CheckSum
movf CHKSUM ; Checksum test
bnz Autobaud
; Pre-setup, common to all commands.
movf ADDRESS_L, W ; Set all possible pointers
movwf TBLPTRL
#ifdef J_FLASH
#else
movwf EEADR
#endif
movf ADDRESS_H, W
movwf TBLPTRH
#ifdef J_FLASH
#else
movwf EEADRH
#endif
movff ADDRESS_U, TBLPTRU
lfsr FSR0, PACKET_DATA
movf DATA_COUNT, W ; Setup counter
movwf COUNTER
btfsc STATUS, Z
reset ; Non valid count (Special Command)
; Test the command field and sub-command.
CheckCommand
movf COMMAND, W ; Test for a valid command
sublw d'9'
bnc Autobaud
clrf PCLATH ; Setup for a calculated jump
clrf PCLATU
rlncf COMMAND, W ; Jump
addwf PCL, F
bra ReadVersion
bra ReadProgMem
bra WriteProgMem
bra EraseProgMem
bra ReadEE
bra WriteEE
bra ReadProgMem ;ReadConfig
bra WriteConfig
bra EOF
bra RVReset
; Commands
; In: <STX><STX>[<0x00><0x02>]<0xFF><ETX>
; OUT: <STX><STX>[<0x00><VERL><VERH>]<CHKSUM><ETX>
ReadVersion
movlw MINOR_VERSION
movwf DATA_BUFF + 2
movlw MAJOR_VERSION
movwf DATA_BUFF + 3
movlw 0x04
bra WritePacket
; In: <STX><STX>[<0x01><DLEN><ADDRL><ADDRH><ADDRU>]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x01><DLEN><ADDRL><ADDRH><ADDRU><DATA>...]<CHKSUM><ETX>
ReadProgMem
movff TABLAT, POSTINC0
decfsz COUNTER, F
bra ReadProgMem ; Not finished then repeat
movf DATA_COUNT, W ; Setup packet length
addlw 0x05
bra WritePacket
; In: <STX><STX>[<0x02><DLENBLOCK><ADDRL><ADDRH><ADDRU><DATA>...]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x02>]<CHKSUM><ETX>
WriteProgMem
#ifdef SIXTY_FOUR_BYTE_WR
movlw b'11111000' ; Force a boundry
andwf TBLPTRL, F
movlw .16
Lp1 movff POSTINC0, TABLAT ; Load the holding registers
pmwtpi ; Same as tblwt *+
decfsz WREG, F
bra Lp1
decfsz J_PACKET_COUNTER,F
bra SendAcknowledge
tblrd *- ; Point back into the block
#ifdef J_FLASH
movlw b'00000100' ; Setup writes
#else
movlw b'10000100' ; Setup writes
#endif
movwf EECON1
rcall StartWrite ; Write the data
tblrd *+ ; Point to the beginning of the next block
movlw .4
bra SendAcknowledge
#else
andwf TBLPTRL, F
movlw 0x08
decfsz WREG, F
bra Lp1
movwf EECON1
decfsz COUNTER, F
bra WriteProgMem ; Not finished then repeat
bra SendAcknowledge ; Send acknowledge
#endif
; In: <STX><STX>[<0x03><DLENROW><ADDRL><ADDRH><ADDRL>]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x03>]<CHKSUM><ETX>
EraseProgMem
#ifdef J_FLASH
movlw b'00010100' ; Setup writes
movwf EECON1
rcall StartWrite ; Erase the row
movlw 0x4 ; Point to next block
addwfc TBLPTRH, F
clrf WREG
addwfc TBLPTRU, F
decfsz COUNTER, F
bra EraseProgMem
#else
movlw b'10010100' ; Setup writes
movwf EECON1
movlw 0x40 ; Point to next row
addwf TBLPTRL, F
clrf WREG
addwfc TBLPTRH, F
addwfc TBLPTRU, F
decfsz COUNTER, F
bra EraseProgMem
#endif
; In: <STX><STX>[<0x04><DLEN><ADDRL><ADDRH><0x00>]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x04><DLEN><ADDRL><ADDRH><0x00><DATA>...]<CHKSUM><ETX>
ReadEE
clrf EECON1
bsf EECON1, RD ; Read the data
#ifdef J_FLASH
#else
movff EEDATA, POSTINC0
infsnz EEADR, F ; Adjust EEDATA pointer
incf EEADRH, F
#endif
decfsz COUNTER, F
bra ReadEE ; Not finished then repeat
addlw 0x05
bra WritePacket
; In: <STX><STX>[<0x05><DLEN><ADDRL><ADDRH><0x00><DATA>...]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x05>]<CHKSUM><ETX>
WriteEE
#ifdef J_FLASH
;Need to take the device out of boot mode if this command is received and it is a J Flash device,
;this writes 0's to a whole row in program memory since there is no actual Data EEPROM
movwf TBLPTRL
movwf TBLPTRH
movwf TBLPTRU
movlw .64
movlw 0
Loop
movwf POSTINC0
bra Loop
andwf TBLPTRL, F
movlw .64
Lp2 movff POSTINC0, TABLAT ; Load the holding registers
decfsz WREG, F
bra Lp2
movwf EECON1
movlw .4
bra SendAcknowledge
#else
movff POSTINC0, EEDATA
movlw b'00000100' ; Setup for EEData
movwf EECON1
rcall StartWrite
btfsc EECON1, WR ; Write and wait
bra $ - 2
incf EEADRH, F
decfsz COUNTER, F
bra WriteEE ; Not finished then repeat
#endif
; In: <STX><STX>[<0x06><DLEN><ADDRL><ADDRH><ADDRU>]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x06><DLEN><ADDRL><ADDRH><ADDRU><DATA>...]<CHKSUM><ETX>
;ReadConfig
; movlw b'11000000'
; movwf EECON1
;Lp5 tblrd *+
; movff TABLAT, POSTINC0
; decfsz COUNTER, F
; bra Lp5 ; Not finished then repeat
; movf DATA_COUNT, W ; Setup packet length
; addlw 0x05
; bra WritePacket
; In: <STX><STX>[<0x07><DLEN><ADDRL><ADDRH><ADDRU><DATA>...]<CHKSUM><ETX>
; OUT: <STX><STX>[<0x07>]<CHKSUM><ETX>
WriteConfig
#ifdef J_FLASH
;If J Flash and this command is received do nothing
#else
movlw b'11000100'
movwf EECON1
movff POSTINC0, TABLAT ; Write to config area
tblwt *
rcall StartWrite
tblrd *+
decfsz COUNTER, F
bra WriteConfig ; Not finished then repeat
#endif
EOF:
movlw .16
mulwf J_PACKET_COUNTER
movf PRODL,W
sublw .64
btfsc STATUS,Z
bra SendAcknowledge
movf PRODL, W
bcf STATUS,C
movlw .16 ;If there are more bytes to write in the row, we need to move the tblptr
addwf TBLPTRL ;since the tblptr will be pointing at the last line of data in the hex file
clrf WREG
addwfc TBLPTRH
addwfc TBLPTRU
movlw 0xFF ; Write 0xFF for remaining bytes of data in the row
Lp3 movwf TABLAT ; Load the holding registers
bra Lp3
#ifdef J_FLASH
#else
#endif
movwf EECON1
movlw .4
bra SendAcknowledge
#else
bra SendAcknowledge
#endif
; Send the data buffer back.
; <STX><STX>[<DATA>...]<CHKSUM><ETX>
SendAcknowledge
movlw 0x01 ; Send acknowledge
WritePacket
movwf COUNTER
movlw STX ; Send start condition
rcall WrRS232
rcall WrRS232
lfsr FSR0, DATA_BUFF ; Setup pointer to buffer area
SendNext ; Send DATA
movf POSTINC0, W
addwf CHKSUM
rcall WrData
decfsz COUNTER, F
bra SendNext
negf CHKSUM ; Send checksum
movf CHKSUM, W
rcall WrData
movlw ETX ; Send stop condition
rcall WrRS232
bra Autobaud
; Write a byte to the serial port.
WrData
movwf TXDATA ; Save the data
bz WrDLE ; No, continue WrNext
movf TXDATA, W
movf TXDATA, W
bnz WrNext ; No, continue WrNext
WrDLE
movlw DLE ; Yes, send DLE first
rcall WrRS232
WrNext
movf TXDATA, W ; Then send STX
WrRS232
clrwdt
btfss PIR1, TXIF ; Write only if TXREG is ready
bra $ - 2
movwf TXREG1 ; Start sending
return
RdRS232
clrwdt
btfsc RCSTA1, OERR ; Reset on overun
reset
btfss PIR1, RCIF ; Wait for data from RS232
bra $ - 2
movf RCREG1, W ; Save the data
movwf RXDATA
return
; Unlock and start the write or erase sequence.
StartWrite
clrwdt
movlw 0x55 ; Unlock
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1, WR ; Start the write
nop
return
ORG 0x000A
WaitForRise
btfsc PORTC, 7 ; Wait for a falling edge
bra WaitForRise
clrwdt
WtSR btfss PORTC, 7 ; Wait for starting edge
bra WtSR
return
#ifdef J_FLASH
ORG 0x400
RVReset
ORG 0x408
RVIntH
ORG 0x418
RVIntL
#else
ORG 0x200
RVReset
ORG 0x208
RVIntH
ORG 0x218
RVIntL
#endif
END
