installer69
Hi, my car has remote boot/trunk opening but you have to push a button on the lid to close it.
After much playing I have located the wire in the latch that goes +12v when the remote is pushed to release the latch and the wire in the close button that goes to earth when pushed to close the lid.
At first I thought that a simple 12v relay would do the trick but the (quite sensible) issue is that the close button is inactive whilst the latch is receiving the open pulse.
So, I made a little circuit with 2 555 timers, The problem is my circuit requires an earth trigger and provides a +12v output pulse after 1 second which works perfect but means the addition of a relay at each end. I have been pointed in the direction of a 4001 which may do the trick but cannot understand enough about one to allow me to do what I want so this is where I ask for your help.
Just to reiterate, The boot release button provides a +12v pulse and my circuit needs, after a 1 second delay, to send an earth pulse.
Current circuit attached but press switch to activate on left hand side of picture has been replaced by a +12v triggered relay.
Also, at the moment I have the circuit powered from the trunk light so that it is only powered up when the lid rises but the circuit goes through its cycle when first powered up and sends the close trigger before the lid is fully open thus stopping it half way up. I could change caps/resistors to extend the delay or power the circuit all the time but both options seem messy if there is a simpler one chip/no relay solution.
Many thanks
Many thanks
