Boosting output to run LED's
t0pP8uZz
I have recently coded a LED fader, Which fades LED's (Light emitting diodes)
The PIC im using can support max 5.5v power source.. And i must connect + to the pins on the PIC. And i can only run about 8 LED's on this without them being too 'dim'
Im wondering if anyone as any ideas about adding external components onto the PIN between the pin and the LED's to get a boost of power to run more LED's?
Like could i use a transistor to connect the BASE of it too the pin, Then do something with the emitter and collector that will help me run more LED's
Any suggestions! Thanks
you can use a transistor
PICs can usually source about 25mA per port which should be enough to light a LED
if its not enough, like you said you can use transistor as a switch in which case the current would be limited only by the power sources current limit
With a base current of 25mA a transistor can drive 750mA very well. A darlington transistor can drive many amps very well.
The transistor is linear, it is not a switch.
