rascupanamuha
I have a problem with my BMS and tried a lot of things trying to repair that but without succes for now.
Here is what i found out. When i discconect +5V_mES, switcher shoud be disabled and +5V should be 0V. But eventhough SHDN is on 0V, when i measure +5V line, there is 3-4V remaining. If i short +5V and GND, everything stops like it should be and remains in that stage. That happens also if i put 100ohm resistor from line +5V to GND. Now when you enable switcher, there is +5V, and when you disconnect +5V_mES, there is no more power in the board.
Also if I disconnect Q2 everything works. If i connect C and E of Q2 when its not soldered, problem returns.
I dont know where do i gat that 3-4V on 5V line when disabled so could could someone please help me?
