Hi, this is a project for my university.. not a student project or a school assignment, but an academic project for research (I do not get paid for this). We are looking for this project to benefit us in some upcoming robot competitions.
We need to evaluate DC motors, and I've seen this kind of problem here at ETO, and at my university, quite a few times. Below is my design for a simple "good enough" dynamometer for testing hobby brushed and brushless DC motors and maybe other cheap DC motors. The design is for brushless motors with Y winding.
Simply put.. there is a BLDC motor with electronic speed controller (ESC) which drives an identical motor connected as a generator. The generator load is purely resistive. The flywheel provides the reactive load. Flywheel is supposed to be constant, but the resistive load needs to be variable.. either in steps or smoothly. This setup can act as a simple test-bench of a dc-motor driven vehicle.
All input is welcome, but I have few specific questions:
1) Can I treat the node labeled "common" the same as "Neutral" of a traditional 3-phase generator.. normally the neutral would be the point where all the generator coils are connected together (middle of the motor drawing). I would like to treat this "common"-node as reference point for all measurements for the generator (current and voltage.. and frequency). The goal is to measure the power generated (and consumed by the resistors) and the (peak) voltage generated. Is my idea ok? All resistors are the same value.
2) How could I implement an electronic control of the load? Simple way would be to use relays to switch parallel resistors on/off for each resistor. But, is there a clever/simple way to get more control of the load (smooth ramp of increasing load)?
- Could I tie the "common" node to a solid ground (power supply ground) and use FETs to bypass resistors with high-frequency PWM? Or, to connect resistors on/off with fets. Will the FET intrinsic diodes be a problem?
3) Any comments on the drawing.. any mistakes? I'm rusty on mechanical design and combining electrical and mechanical design is kind of awkward. I kind of winged the "synchronized control of load resistor" -part. Anyway.. this is just a concept drawing.
The motors are identical.. at least for the first prototype.
There will be a microcontroller etc. to take all measurements. The final calculations will be done offline on desktop computer. That is no problem. I can provide all that when the project is done.
