Im turning a pc power supply into a 12v psu to run a car amp, i got it running fine using a few 12v rails and a few grounds together and connected the green wire to ground to switch it on.
i gradually increased the wiring until i had all the 12v rails and most of the grounds connected.
all was fine so i cut the rest of the wires short (removed the atx block) to tidy it all up. as soon as i did this the psu refuses to run, it starts for a split second and then is dead.
i had the same problem with another atx psu (brand new).
the thing i cant understand is that theres nothing connected to anything else in the block itself, every pin is isolated from everything else so surely it shouldnt make the slightest difference cutting the unused cables???
