Grossel
Hi folks.
I have (or had) an old car that I now take apart various parts for re-purposing, maybe just selling.
Some wires, especially those that are found behind panels - they often have a foam that sticks to it to prevent noise. The foam is relative easy to remove, but the glue underneath not so much.
The glue isn't hard, but it sticks, it's dirty and doesn't disolves much when soap are used.
Yesterday I taught I've found a good solution, using steel wool (the kind where soap are added). Well, the result was seemingly fine, but only until the wires was dry. Then I found that there was still glue to the wires. I was able to somehow remove most of the glue by just using dry toilet paper, but I think it takes much manual labor compared to the results.
This are the methods I've tried - but none are very efficient because the glue are water and soap resistant:
This is just a hobby project, so not s big deal exept I have this feeling that there must be a clever way to get rid of this sticky glue on some wires. Strong/magic acid or base is not an option.
- Old tooth brush and sope (removes the most amount of dirt, don't remove much sticky glue)
- Steel wool (takes away much of the glue, but when the glue are wet, it doesn't feel that sticky and therefore lack of feedback on whether more glue are left until wire are dry)
- Dry toilet paper (must use force to gain any effect and therefore labor intensive, and still tends to left a thin film of sticky glue on the surface)
