abhishek singh said:hi,
This is my first post in this forum so mistakes are forgivalbe. to measure the internal resistance you may take a high watta wire wound potentiometer and connect it to batteries terminals. now turn the knob so that the voltage between both the terminals is just half of the initial unloaded battry voltage, dont keep the potentiometer always connected just measure and disconnect. turn the knob again and measure again untill you get half point. measure the resistance of potentio meter which will be equal to battries internal resistance. dont use this method with low resistance battries.
abhishek
bogdanfirst said:here is a better way to mesure the internal resistance of a battery.....
but you don't only need the multimeter......you also need a resistor....
for normal batteries, liow voltage , use a resistor like 10-500 Ohms. for 1.5V bats i recommend around 150R.....or 100R for your accurate mesuring use 5% or even 1%. also it is better to use 0.5W or 1W . ..so you can be sure not to burn them....
anyway the value will be considered R
the multimeter will be used as a voltmeter
first it is important what kind of multimeter you are using.....if you are using a digital one it should have an impedance of 1Mohm...so this quite larger compared to ther resistor you are using.
ok....here is how to do it....
first you connect the multimeter and mesure the voltage at the battery without any load on it. this will be noted E.
now connect the resistor to ther battery and mesure the voltage across it. note that as U.
now you will find the internal resistance of the battry as being r=R(U/E-1)
understood?
do you need the calculations.....and the explenation of where the formula came from?
