My cheap RC airplane came with an 8.4V Ni-MH battery made with 7 AAA cells.
The power was barely enough for the plane to fly level then slowly get lower and land. Each flight lasted only a minute or two if it didn't stall then crash. Wind caused spectacular crashes.
I tried another similar battery and it performed the same.
Then I tried two Lithium-Ion cells from a lap-top pc that are heavier and have a typical total voltage of only 7.4V. The plane quickly goes up high like a rocket and the charge lasts for a long time (15 minutes).
The motor's speed controller circuit shuts off the motor when the battery voltage gets too low so the radio controls still work. After a short rest the "discharged" battery powers the plane again for a long time. After the second time and after a second rest the battery measures 7.7V which is far more than the 6V minimum allowed.
Now I have a bunch of lithium-ion batteries. I can swap them quickly.
I charge them with an LM317 regulator fed "9V" from a 500mA wall-wart and the regulator is set to 8.4V. Each battery is fully charged in less than 4 hours.
Lots of fun.
Lots of fun.
