AVR Studio Entering Programming Mode.. Failed!
Marks256
I just went to burn more code to a atmega16 i've been working on all day, and all of a sudden i got the error
Entering programming mode.. Failed!
Leaving programming mode.. OK!
with a "quick tip" saying something about making sure the ISP frequency is less than the clock. So i tried every number in the list of ISP freqencies, all the way from 921.6kHz down to 603Hz, and still no go.
This is the STK500 clone i'm using
:( i really have no clue what is going on. Then i thought it was a problem with the fuses, so i started messing with them, and now i don't remember what they were set at. :(
well it really doesn't matter anymore. I just managed to erase the firmware on the STK500 programmer...
I am going to call it a night before i start to start wrecking more stuff...
Salgat said:
I hope I don't come off as rude, but why did you buy a clone when you could have bought the real deal for $3 more? :p
Not rude at all. I didn't know I could get the "real thing" still. Plus i was looking on ebay, and they don't seem to have very many real STK500's on there.
I bought a new STK500 clone yesterday, it should be here soon. Perhaps i'll be able to resurrect the broken ISP with the new one.
My new STK500 Clone came, and programming failed again with the "Entering Programming Mode.. Failed!" error. So i swapped the Atmega16 for a new chip, and low and behold it worked! I am assuming a fuse decided to turn which put the device in program once mode.
So, it works now... solution was a new chip.
sounds like you encountered an error while programming the fuses.
I got a cheap programmer to restore the fuses on lots of avr's here:
it works good.
clone upgrade how-to
the chinese clone avrisp use a different interface IC,
which wont firmware-upgrade via avr studio
so....to acheive the firmware upgrade use a little trick posted on the
AVRfreaks forum;a seriously cool resource for AVRmicro's!:)
edited version:-
If you upgrade the software while it is plugged into the target system, it corrupts the programmer.
You can force the programmer into boot mode by disconnecting it from the target system, and shorting TDI to TDO. If you have the 6-way connector (AVR ISP mkII) then you need to crack open the case and short pins 1,3 of the un-stuffed 10-way header (beside the USB connector)
it will then upgrade from AVR studio
solder in a 5x2 header and use a 0.1" jumper, so next time its easier
