/me slides the topic on track again
The switch to the door is not the problem I guess, I can also use a touch/movement sensor located in the wall. problem for me will be to figure out the motor control bit, think I will start a "Help! Newbie wants to learn PIC programming" topic in the microcontroller section.
I came across www.hobbyengineering.com and it seems like they have almost everything I need, there is good selection of small geared DC motors that may do the trick for opening/closing. I was planning on ataching a small rubber wheel to the motor and let this drive the door on the upper edge.
If someone can mention some things that are a "must" to have before starting a project like this that would be nice, all I have is a voltmeter and soldering iron.
