Automatic Battery Charger With SCR
minnik
I am looking for it since one month. But i couldnt find yet:(
How can i do it ? Do you have this circuit ?
Hi Minnik,
I didn't have to look for it so long to find it but it's probably not
the right one, but here it is. :confused:
For charging a 12 volt battery, a 300 ohm 1 watt resistor should
be inserted in the collector of Q2, R3 should be increased to 400
ohms and the secondary voltage of T1 should be doubled.
on1aag.
Thanks. On1aag
Mr.Gayan Soyza;
its a homework about SCR.
its unimportant what batteries.
the circuit must have SCR.
if you have a simple circuit batery charger with scr. may you give it to me.
You looked for a month and it is a homework problem? Isn't it _way_ past due? Why won't you work it out yourself anyhow?
because. i colud't do it. i tried in ewb and isis for it. and after i started to looking for.
thanks for all reply.
