Anyone have experience using voltage reference IC AD586?
flat5
I built the simple circuit but the output is 5.46 volts. Not 5 volts.
Three meters concur.
Circuit is SO simple I can't see that I've done something wrong.
Using a bench supply at 12 volts.
Added the 1uf low noise cap but not the trim pot.
Built on a perf board and the IC was socketed as the last step.
What circuit?
It should work.
Have you double checked the pinouts and wiring?
Can you post a picture of the wiring?
The Output, Trim and GND pins are adjacent to each other.
Could it be that there is a blob of flux or whatever, bridging the pins and affecting the output?
Otherwise, there is not much to go wrong with that circuit!
I'm m bare assed :)
I did not see the shorts until faced with the full screen pic.
I should know better! Always check with lots of light & a magnifier!
Very bad solder work - and with a new solder station!
(I was doing the work at 3am)
I just got some .3mm solder and will start using it.
I believe I've applied too much solder.
Also I think I should have cleaned the board before soldering.
The solder might have flowed better and I would not have used so much.
It's all cleaned up now (relatively speaking).
Using most of my DMMs the reference reads at the banana jacks using cheap probes
4.998
4.96
4.96
4.98
4.98
5.05
5.00
Average is 4.9897142 volts
So I don't know what to believe :)
In reality, the first number is 5.00 to three sig figs. recomputed, the average is 4.99 to three sig figs. Accuracy is another issue, because that might be +-1 digit.
The probes generally won't make a difference. Depending on the grade you have 4.980 to 5.020 V for the J device.
Remember that accuracy and resolution are different.
So, if your meter is +-1 mV and +1 digit, you have to treat it accordingly.
Thank you, KISS. I forgot about all that. I'll read a wiki or something.
Even with my data if averaged to three digits it is 4.99.
It is indeed AD586JN High Precision 5V Ref. from Futurlec.
