Allowed frequency band and transmission power at homes and industry
alphacat
Hello.
Could anyone please tell me where could i find the allowed frequency band and transmission power at homes and industry?
I'm talking about having units that wirelessy communicate with each other at homes/industry.
Thank you very much.
You question is so vague it's not possible to answer, aside from saying Google it.
What spectrum range are you interested, what power limit?
In the US there are many bands of spectrum dedicated to specific uses which are allows certain tolerances on transmit frequency, modulation methods, and power. So you have to mention at the very least the frequency band you're looking for. Home or Industry is irrelevant, doesn't play a roll at all. The FCC has similar regulating branches in many other countries, some countries have none at all.
I'm thinking of the few really small poor countries that simple have no need for a regulatory body of that nature.
Are they any such?, a regulatory body doesn't have to cost much - and the issuing of licences should make it self funding anyway.
You can't just transmit what yoiu want were you want, that would cause chaos, and outside the country as well.
the "Russian Woodpecker" was an over-the-horizon radar, and had a nasty habit of coming up on various frequencies that were in use elsewhere. although i remember hearing it often on frequencies that weren't in use as well, so i don't think it's frequency selection was always with the intent of jamming, but it may have been used as a jammer from time to time... there was also a US version that used a frequency modulated sweep at about a 20hz rate, but it locked out SW broadcast and ham bands, so it wasn't well known. i do remember being an RTTY operator in the Army, and having it come up on our net frequency one night...
the OP is from France, and the CEPT is where he should look first.
The FCC only regulates the USA and its territories
This is per the ITU treaty on frequency spectrum use. The ITU is the international agency that "governs" (not really) spectrum use. Each independant nation follows ITU treaty or chooses not to on its own accord.
It has nothing to do with poverty. Island nations in the middle of the Pacific follow international treaty. Having a regulatory agency is here nor there.
It depends on the politics of the government and nothing more. It isn't a matter of money but rather a matter of taking treaty serious enough to give it any priority.
The FCC is one of the worst agencies in that regard. Take a listen on the 11 meter band sometime if you don't believe me.
Worth noting is that some countries have rules related to the emissions in terms of power/freuqency/mode and they further regulate the equipment based on the manufacturer. An example (that may be incorrect but I use it to illustrate a point) is that a WiFi router may be accepted by the FCC as long as used as originally manufactured. Modifications to the device that aren't part of the manufacturer's plan are not allowed (alternative antennas, etc).
As others will point out, the enforcement of regulations is quite variable and is probably more dependent on who an offender might bother.
the 11 meter (CB) band is a wasteland. CB was only a rarely used hobby band until 1970 when the FCC expanded it to 40 channels and dropped the requirement for a (free) license application. not to mention all of the media hype that multiplied the popularity of it...
