Adding HEX bits in a byte.
You are missing the fact that some of these settings are bits 4~5 or 6~7
Take my example
PA = 128
MaxPower = 64
OutputPower = 7;
PA is bit 7
Maxpower is bits 4, 5 and 6
Output power is bits 0, 1, 2 and 3
So
Const PA = 0x80
Const MaxPower = 0x10 ( lowest ) thro to 0x70 ( highest )
Const Output power = 0x00 ( lowest ) to 0x0f ( highest )
Each bit ored together make up the final register
A penny has just dropped! Unless each section 0x?? is set to it's correct bit number (As has been pointed out before), this ORing can't work.
I'll re try in Oshonsoft with different numbering.
C.
Take my example
PA = 128
MaxPower = 64
OutputPower = 7;
PA is bit 7
So
Const PA = 0x80
Hi I
Your comment came as my penny was dropping.
I'll try a few of the suggestions in Oshonsoft, and see if they work.
C.
I've just tried this long hand method of setting the REGISTERS
Const regopmode = 0x01
Const w_regopmode = 0x01 or 0x80
Dim lora_fsk_reserved_low_sleep As Byte
lora_fsk_reserved_low_sleep = %10001000
Dim lora_fsk_reserved_low_tx As Byte
lora_fsk_reserved_low_tx = %10001011
Dim lora_fsk_reserved_low_rx As Byte
lora_fsk_reserved_low_rx = %10001101
I think the answer to the original question I asked would take a better programmer than me. With the method above, I can visualise the bits better. I'll see how I get on as the list gets longer. It's possible that once I've understood the bit .number method, if it's easier may change later.
Thanks to all for their input, much appreciated.
C.
remember
Pseudocode
To set a bit you OR: A= A .OR, value
To clear a bit, you AND the inverse: A=A .AND. .NOT. value
It's a lot easier to operate on unsigned integers.
remember
Pseudocode
Hi K,
I'm sure your answer will be easy to understand, for programmers practiced in operators, but for dunces like me, it will need to be spelled out, if you have the patience.
KIS:)
When I am practicing with operators, I use this method. I use a calculator and write the answer like this: %10000000 or %00000001 = %10000001
I think that when DOTs are used this refers to a BIT, is this correct? So far I haven't tried changing bits on their own, but instead change the byte e,g, %00000011 to %00000010. I know this is the same, but it takes time for the 'penny to drop' and be remembered. I now know that unsigned means no negatives, and in what I am doing there aren't any.
Thanks, C.
Set
Value to set (2^2) = 4 = 0000 0100
Present value: 1010 1011
1010 1011 initial value
0000 0100 bit to set
0000 0111 after .OR. operation
Clear
0000 0100 bit to clear
1111 1011 complement of bit to clear NOT (0000 0100)
1010 1011 final value after ANDING, Note the bit is unchanged because it was clear already
Another comment:
1010 1011 converted to HEX = 10d 11d = ABh; You just group into 4 bits.
and finally
010 101 011 converted to Octal = 253o ; You just group into three's instead of 4 from the LSb
Back in the day (mid 70's), octal was very common for me. My guess is we had to enter numbers from physical switches, thus Octal was easier.
Unsigned means no negatives which is true. We generally use 2's complement notation, so there is only one zero in the set of numbers. Thus a 16 bit number has a range of -32768 (1111 1111) to 32767 (0111 1111). Many integer 2's complement 16 bit systems will make 32767+1 = -32768. I used that fact in high school to crash our time-shared computer. The crash dump told them it was our school, so they changed the password until someone, me, confessed. I wasn't supposed to tell anyone how I did it and not do it again.
Sometimes you have to deal with magnitude and sign.
remember
Pseudocode
Hi K,
KIS:)
I think that when DOTs are used this refers to a BIT, is this correct? So far I haven't tried changing bits on their own, but instead change the byte e,g, %0000001 to %00000010. I know this is the same, but it takes time for the 'penny to drop' and be remembered. I now know that unsigned means no negatives, and in what I am doing there aren't any.
Thanks, C.
Set
Clear
Another comment:
and finally
Hi k,
This deserves a printout and a long stare. Much appreciated, thanks.
Can I ask a bit more? How does MASK fit into this, please?
C.
A bit MASK effectively covers the bit your interested in.
So if you had 0001 1001 and wanted to know if bit zero (2^0) is set, the MASK is: 0000 0001
Thus the test is IF VALUE .AND. MASK = .TRUE. then the bit is set. If it's FALSE, then the bit is not set.
My C is too rusty right now. The .AND. stuff is actually from the FORTRAN ERA. My first C program was an operating system with instruction set simulation done as a team of two. It was a crash course in C.
Basically .FALSE. has a value of zero and .TRUE. generally has a value of -1, but anything non-zero tests as TRUE in some systems,
The Boolean stuff and the integer stuff sometimes gets "mixed up". In C you have "typecasting"
Hi K,
I'll add this to my printout sheet. Your C is good enough for me.
I learnt BASIC when my son got his first computer in the early 80s, I still struggle with BASIC, but because of all of the help I get from this forum and others, I keep enjoying this hobby. (Not to mention the headaches :) )
Thanks, C.
My first any programming project have been HUGE. Like my FIRST FORTRAN program took me and one other person 9 months to code nearly full time. LabVIEW is a data flow programming language which is the deFacto standard for controlling Instrumentation. https://store.digilentinc.com/labview-home-bundle/ It was very Bizzare learning when it was in it's infancy and was constantly changing. One problem is, instrument drivers are released by the manufacturer of the instrument on a particular version, so your constantly upgrading.
I spent learning and managing a $100,000 USD upgrade project. I was a bit over extended, managing, doing hardware and software design and sometimes development.
One program in this upgrade ran for 17 years with no changes and no hard drive crashes. The only computer issue was dust and a floppy drive replacement.
When I did RCA COSMAC 1802 Assembly language programming, that processor used a "pass the program counter" method. Any register could be the program counter.
One of the first routines I wrote was a subroutine call and return. The entire program to control a model train gantry crane was hand coded. I owned an Amiga computer at the time. See: https://en.wikipedia.org/wiki/RCA_1802
Hi K,
Are you saying that you designed LABVIEW? If so that is impressive. If I was starting again, I would have a closer look at it.
My biggest project was a Photographic laboratory, all working from ZX Spectrums. I could process any film from 35mm to 1/2 plate, black/white colour and transparency. I was a photographer and what luxury to have it. I could then print 16inch by any length paper. Happy days:)
C.
No. I was designing a 4-terminal I-V converter as a front-end for a Lock-in amplifier all during the time I was managing software design using Labview. LabView wasn;t mature at the time, so I had to code "flicker-fixers" so that numbers would not flicker and all sorts of things. We used a program that could make keystrokes kit buttons, So, you have the Human Interface aspect. This was used for production test so you interacted with the program every 3 minutes.
The initial design didn't work out. The laser printer took too long to warm-up, so printing of the results was done in a batch process. I wanted to do the testing in a different way, but it took 17 years to adopt. So, project management for a huge software/hardware project is a mess.
I did very little of the actual programming, but all of the software design and I did write all of the routines that talked to instrumentation. Program design used a "simulate mode" so the instruments didn't have to be present, so that 3 minute cycle could be eliminated during development. The person doing the programming didn't know LabView either.
The program I did as a team in the 80's was really cool. The IBM PC didn't exist at all. We had 7 PID loops, recipes etc. using a real-time OS. The hard drive the size of a suitcase and the company going under meant it had to be replaced. So, with much reduced functionality, 7 programmable temperature controller were used.
Hi K,
Still impressive, and not my cup of tea. I suppose things would have been different if I had chosen a different path.
In the 70s, I had to help set-up dust monitoring in the London airport computer building, involving a sea of computers. The nearest I got to computing, was to look in one of the boxes and watch the lights flashing.
C.
Making a comeback now..... I have just installed ZXbasic... I always used ASM on the old ZX but now this lets me do anything!!! Its based on freebasic and compiles to machine code so the speed is brilliant!!
Hi I,
I bought the Spectrum for my son for Christmas as inducement to do better at school. As you know there was no monitor with it, as it plugged into the Tv. So instead of watching Tv, I 'had' to watch 'A dot' arriving on the screen, then a circle etc. I would pick up the excellent manual which is written in a way, that I could follow. I learnt BASIC, by forced osmosis. We then got things to work from the rear socket of the spectrum, and I was hooked. Not forgetting MANIC MINOR.
C.
