Chaps, I have a relic psu on my bench, it has 2 independant lm723 regs in it.
I'd like to stuff an led (one for each reg) on the front panel (and maybe a 555 to trigger a beeper when current limit is activated) so I know if the supply is in CV or CI.
I found a schematic for another lm723 supply here:
The documentation doesnt say what d5 (led) is for, it looks like it might be a current limit indicator, hence my interest, if so how does it work?, I'm more used to microcontroller circuits.
I had an idea for a current limit led before I found this schematic, connect the base of an npn tranny through a resistor to the cl pin, and the emitter to the cs pin, then connect the cathode of the led to the collector, and up to the supply for the '723 through a resistor, basically connecting the tranny that switches the led base emiter accross the current sense resistor, so that what the vdrop > 0.6v the led comes on.
Which should I go for my idea or the attached schematic.
