ADC conversion clock?
Pommie
Most Helpful Member
I'm using one of the newer Pic16 series chips and the ADC has become a lot more complex. However, the writers of the datasheet seem to have gotten lazy. In this table they've skipped a lot of rows (I think),
The way I'm reading the above is that 1.0uS is a good period for TAD. I'm running at 32MHz and assume that there's a missing row of Fosc/32 where my time will be 1uS.
To further confuse the matter, the register where you set this value seems to have a typo,
Surely those (divisor) values should be halving each row and Fosc/124 is a typo and should be Fosc/32?
Is there another document that describes this?
Thanks for any comment.
Perhaps just use the MCC to set it up, then cut and paste the setup code to your own application.
I keep having to setup a dummy project so I can do just that. Oh well, that's a job for in the morning.
One interesting thing I've found with PPS is that is you put a CCP or PWM output on a pin you can no longer use it as a simple I/O - it's PWM (or capture) only.
I tend to set a dummy project up and return to it if I'm using the same device, and add any extra settings - then cut and paste.
Yes, if you allocate a peripheral to an I/O pin you have to unallocate it to use it as an I/O later.
I do a lot of low power stuff, and if you're using UART's the TX pin is high by default - so when you enter sleep mode current flows out the TX pin killing your low consumption.
Shutting the UART down doesn't help, so I found the answer is to shut the UART down, reallocate the TX pin elsewhere via PPS, and then with the TX now a standard I/O set it low. On waking from sleep, do the reverse.
I don't see anything wrong with the table. The divide ratio is 2 * (ASCCS<5:0> + 1)
The 6 bits of ASCCS<5:0> read as a binary number in the range 0 - 63
Adding one gives 1 - 64
Multiplying by 2 gives 2 - 128
If you want to divide by 32, ASCCS<5:0> should be 15 or 001111
You are, of course, correct. Guess I got confused due to the top table going in binary steps and assumed the bottom table was a typo. Morning here now, let's see if a clearer head helps me to get this working.
