AD711 equivalent
Why not use the AD711?
I don't know how you are going to use the op-amp.
I compare the speed of the amps 4mhz.
Look for min/max supply voltage. (what supply are you using?)
13 volts/uS
Noise level?
Output current?
@ronsimpson: i have a faulty PCI card and burned AD711 on it. i want to replace the op-amp, but i cant find AD711 in my local. i test with TL071 and it worked but i want to replace the op-amp the best equivalent of the original one.
the op-amp is used in 0-10V DAC output as current-to-voltage converter
