Acoustic emission preamp
There is not "one" at that URL.
"As applications and testing conditions vary along with customers needs, the applicable amplifier is also different. There are different ways to categorize the amplifiers. For example:"
So, how do you catagorize your needs?
Acoustic emission signals are signals from materials like steel or building materials like cement which are emitted before or at the time of cracking.
the preamp will take the signal in from a sensor the input impedence of the amp is ideally 10kohms 15pf, the signal freq ranges from 20-1200khz freq.
ie the input bandwidth is 1Mhz
Now the main problem ,the input signal is of microvolts so how do
i differentiate between the signal and the noise the good preamps hav a noise level of <2u volts like 1220A by Physical Acoustic corp.[/list]
Two ways to reduce noise at the source is: !. reduce the bandwidth 2. reduce the temperature.
The signal to noise can be improved by using a more sensitive sensor. What is your sensor?
