AC Motor Control
the broucher does explain your solution already
Instructions:
Water flow decreases when the Venturi feature is used. If no air is desired or if you prefer to use the Maxi-Jet with the Prefilter Grid, do not install the Air Tube. Cover the Venturi opening with the enclosed clear-plastic Venturi Plug.
did you try it also without pluging the ventury opening so that it sucks water instead of air? and if you did what was the result?
as for the price of the pump all efforts to reduce the flow rate electricaly are probably more expencive than looking for a new and somewhat smaller version
Robert-Jan
fish Tank Supplies > Fish Tank Pump & Power Head > Fish Tank Power Head > Maxi-Jet & Mini-Jet Powerheads
Maxi-Jet Powerheads & Mini-Jet Powerheads from Aquarium Systems
Aquarium Systems powerheads are very popular and well-reviewed for being sturdy and reliable. Powerful, saltwater safe pumps provide inexpensive, excellent performance with little maintenance. Maxi-Jet powerheads are among the few that can handle the on/off strain of electric wavemakers; they work well in a variety of different flow situations and have excellent lift power for the GPH rating. Silent motors are well-housed to prevent overheating. They also have an optional aerating function. Mini-Jets are small, completely immersible pumps ideal for sump use or smaller applications. Parts available.
Maxi-Jet 400 PH Powerhead 106gph
Regular price: $14.99
Sale price: $13.99 Maxi-Jet 600 Powerhead 160gph
Regular price: $17.49
Sale price: $15.99 Maxi-Jet 900 PH Powerhead 230gph
Regular price: $19.99
Sale price: $18.99 Maxi Jet 1000 Power Head
$17.99
Maxi-Jet 1200 PH Powerhead 295gph
Regular price: $22.99
Sale price: $20.99 Mini Jet 404 Adjustable Flow Mini-Pump
Regular price: $13.49
Sale price: $12.49 Mini Jet 606 Adjustable Flow Mini-Pump
Sale price: $15.99
with these prices there is no way i would consider to modify a pump flow
i would put my efford in trying to change the pump over at the store for one of those adjustible ones with a lower flow rate
i thing if you just change over and don't ask for the price difference that they don't make to much trouble and otherwise you just buy one it's less than $20 (i bett your fish are more expensive)
