AC inductor help
Hi all
I am trying to source AC inductors, I know these are difficult to source off the shelf, even if you could suggest a manufacturer that could make them that would be exteremly useful the following are the properties I am after:
Inductor 1:
22uH, 13 Arms, 17A Peak
Inductor 2:
10uH, 20 Arms, 26A Peak
Any help or suggestions would be greatly appreciated.
Kind Regards
Art
Are these powerline (50/60 Hz) Hz?
If so, if you know a transformer manufacturer, they can custom-make some for you. Emphasis on custom.
Essentially, instead of interleaving the E and I laminations, you form a stack with only "E"s on one side and the "I"s on the other.
Then empirically start adding nonmagnetic spacers to create an air gap between them. That air gap will be very small 3 mm or less. Usually you may require of kapton film layers.
Once that you have achieved the desired inductance, set the gap with hard epoxy.
The resulting assembly will be VERY NOISY. You'll have to pot the complete assembly in a can filled with tar-pitch. Similar to what magnetic ballasts employ.
Yes these are power line, I was afraid it would come to that I will try the suggestions out I was hoping there was a ready made solution out there thanks Art
The inductance values are so small that you don't need an iron core, and you could easily wind these yourself with some heavy copper wire. #20 AWG for the first one and #10 AWG for the second one.
