Nikolai Petrenko
What capacitor should I use as input coupling capacitors? Polypropylene, polyester, silver-mica......??? Or even electrolytic? Too much types and brand: Rubycon, Elna, Nichicon......
For what application?What capacitor should I use as input coupling capacitors? ...
Hmm- nice advice. I have never heard those. Epcos components are always pretty good.I used inexpensive Epcos Polyethelene film coupling capacitors in most of my hifi amplifiers and they sound the same as expensive larger polypropylene capacitors.
Nice Amp Spec. What happened to the power amp that you invested so much time into for Niko in the other thread. Seems such a shame that you would put in so much time, only to have your work go in vain
Nikolai,
I suggest that you use this schematic as the basis of your power amps. It is a classic Douglas Self design and has been optimized for high quality. Yes, it does use a few more transistors than simpler designs, but what is a few transistors here or there between friends. View attachment 95493
Hola atferrari,Hola Spec,
Strictly speaking, would you call the input a long tailed pair?
Speaking of Caps, I came across this useful info on caps awhile back. Pretty good read. The articles are by Capacitor engineer Cyril Bateman.
https://linearaudio.nl/cyril-batemans-capacitor-sound-articles
Another good Bateman article.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=0ahUKEwiSjo3s_tLKAhVO4GMKHV4kAhcQFghOMAg&url=https://www.foxcomputer.se/Understanding%20Capacitors.pdf&usg=AFQjCNHMXIwjx2DfO_OLueApSrpCibaNfQ&cad=rja
Surprisingly it has a lot of the characteristics of the Leach Amp. The transistors I recognize.
Oh no! MPSA05-56 not available!Nikolai,
I suggest that you use this schematic as the basis of your power amps. It is a classic Douglas Self design and has been optimized for high quality and simplicity. Make no mistake, it is a nice amp without being overly complex or expensive. Yes, it does use a few more transistors than simpler designs, but what is a few transistors here or there between friends.
The circuit can be inverted if required so that the two input difference transistors would become NPN instead of PNP. The performance of the amp would be exactly the same with either sex configuration.
It would be nice to get rid of C2 and replace it with a short. I will think about doing that.
Likewise it would be a good move to replace the input electrolytic capacitor with with a hifi solid type.
C9 and C10 would be better at 2m2F with pollycarbs across them.
The layout should be as shown with the similar amps in the transistor equivalent thread.
More decoupling also shown on the amp schematics of the transistor equivalent thread would also be good
VAS= Voltage Amplification Stage
The earth symbols on the schematic are misleading and should be OV supply line
Don't worry about transistor types. There are many that will be suitable.Oh no! MPSA05-56 not available!
