A VHF/UHF video transmitter
agpraneet
I want to buy/build a VHF/UHF video transmitter that is affordable. I wish to hook it up with a camera( a cheap security camera with rca audio and video output) fitted on a r/c car so that i can transmit video to a portable tv. I dont wish to have a separate receiver and hence want the signal to be in vhf uhf range so that the television can catch the signal.
I want it to be cheap as the things i saw on the web comply to my requirements but are too costly. I am located in ncr region, india.
If possible tell me where i can buy it or how exactly can i make one of my own.
I dont have any knowledge of electronic circuits so the former is more preferable.
Actually I have a camera and only need a transmitter
And as I said before, I want to avoid the hassle of a receiver and want to directly transmit to the tv. I wish to fit it on a car and thus carrying the receiver around will be quite cumbersome. Also, I own a portable tv (Casio tv 770C) which is quite handy and hence I want to transmit the video to it. It can catch signals in uhf/vhf range.
If someone can tellme where to buy it in ncr or help me make it,Please do reply
agpraneet
Thanks for the reply
Well I dont need much range actually
anything above 50m sholud suffice
even something below 50m can be considered provided it is cost effective
crutschow
Most Helpful Member
You could use this **broken link removed**
agpraneet
Well the problem with it is that it is quite bulky and hence is very diffcult to mount on a rc car
But thanks all the same
I need something less bulky and less pricey available in india
Super Moderator
Most Helpful Member
You could try using the modulator from a VCR.
crutschow
Most Helpful Member
There are a number on ebay such as **broken link removed**
audioguru
Most Helpful Member
Will the UHF transmitter that is designed for America work with a TV in India?
Maybe the sync frequencies are wrong.
agpraneet
Thank you for showing interest in my problem
Maybe if you give me a circuit that has some backing that it works then maybe i will try to get it made by someone else. But only if it is foolproof.
I dont have a vcr
The problem with that is it accepts input from a rf modulator.
But i need a device that takes composite video input and modulates it and then transmits it
As far as I know, diffrent countries use different systems such as pal, ntsc.
The portable tv i own should be compatible with most of the systems but i dont know about it supporting the american system
agpraneet
Thank you for the replies
actually i have already seen the ebay one but it accepts input from a rf modulator.
I dont have a vcr
The point raised by blueroomelectronics looks very valid but what i say is that i can comment upon it only if i get the thing in my hand and try it
But thanks to all of you
If somebody gives me a foolproof circuit (something that has been tried and verified), then i could try getting it made from someone, as there are far too many circuits available on the web
crutschow
Most Helpful Member
The sync frequencies are determined by the video source not the modulator.
agpraneet
Well can somebody tell me some place in ncr(preferable ghaziabad) where i can find this thing.
Or else can somebody volunteer to make this for me
Or somebody can tell me where to find engineering projects as i saw somewhwere that it is a final year engineering project
Any help will be appreciated
agpraneet
Actually you misunderstood me
This is not my project but just a little interest of mine to make a spy car
The reason i wrote that was just to have someone who might have made this thing or would be willing to make as i have seen many shops claiming to make projects for people
