8051 with real time clock
Your code is not correct... The write to the I2C bus is a specific sequence..
If you want to write to the device you have to:
setup a start condition ( if bus is ready )
write device address ( wait for ack )
write register address ( wait for ack )
write device data ( wait for ack )
send nack ( to stop device )
send stop ( to free bus )
If you want to read from the device you have to:
send re-start( wait for ack )
read device ( send ack if more data needed )
Without this the device won't respond....
I am trying to learn basic programming of ds1307
void I2CStart()
    SDA = 0;
    SCL = 0;
void I2CStop()
    SCL = 0;
    SDA = 0;
    SCL = 1;
    SDA = 1;
send nack
void I2CNak()
    SDA = 1;
    SCL = 1;
    SCL = 0;
    SDA = 1;
ok I saw that tread , now I am trying to make some code myself
void I2C_Init()         //
    SDA = 1;
    SCL = 1;
void I2C_Start()       // start I2C
    SDA = 0;
    SCL = 0;
I2C_write()               //  send data to Ds1307
I2C_write(0xD0);      // address of the DS1307 )
I2C_write(0x00);      // address of seconds register
I2C_write(0x10);       // 10 data as 10 second
void I2C_Ack()
    SDA = 0;
    SCL = 1;
    SCL = 0;
    SDA = 1;
void I2C_Stop()    // stop I2C
    SCL = 0;
    SDA = 0;
    SCL = 1;
    SDA = 1;
void I2C_Start()
    SDA = 0;
    SCL = 0;
I2C_read()
I2C_write(0xD1);      // address of the DS1307 )
void I2C_Nak()
    SDA = 1;
    SCL = 1;
    SCL = 0;
    SDA = 1;
    SCL = 0;
    SDA = 0;
    SCL = 1;
    SDA = 1;
Right!!! The reason we write low level routines is so we can use them in "wrapper " functions
ack, nack, start, and stop need EVER be accessed again...
ReadRtc( addr , data )
start
wite dev addr
write reg addr
restart
read data
nack
stop
Now you only ever call ReadRtc......
I gave you an I2C library.... All you need to do is configure the pins then call RTC read and RTC write
Job done.....
start
wite dev addr
write reg addr
restart
read data
nack
stop
Job done.....
write to device
read from device
what about LED , where is function for LED?. how LED will work ?how LED will know that alarm set for second or minute or hours ?
I think that not big task it will be just using cond if else all, main is how to read and write properly!
write to device
read from device
I don't even know what your LED does????
ok ,look at this in another way
1. mirocontroller send data to RTS DS1307.
2.mirocontroller read the data (alarm Time ) from the ds1307.
3.Then microcontroller send alarm time to active LED
I think I have written code for line 1, and Line 2 . how to write code for line 3 ?
code
void I2C_Init()         //
    SDA = 1;
    SCL = 1;
    SDA = 0;
    SCL = 0;
void I2C_Ack()
    SDA = 0;
    SCL = 1;
    SCL = 0;
    SDA = 1;
    SCL = 0;
    SDA = 0;
    SCL = 1;
    SDA = 1;
void I2C_Start()
    SDA = 0;
    SCL = 0;
I2C_read()
void I2C_Nak()
    SDA = 1;
    SCL = 1;
    SCL = 0;
    SDA = 1;
    SCL = 0;
    SDA = 0;
    SCL = 1;
    SDA = 1;
This makes no sense whatsoever!!!!
Ok I will remove that portion
just for example:
Mcu send data ( 10 seconds ,15 minutes , 1 hours) RTS DS1307
Mcu read data ( 10 seconds ,15 minutes , 1 hours) from RTS DS1307
now mcu send time alarm ( 10 seconds ,15 minutes , 1 hours) to activate LED
I have time array
10 seconds
15 minutes
1 hours
I need to tell led using c program how to write code for point 3?
Hello Vead,
Just wait if you want to do thsi you can perform with simple delay to.
anyway, just use compare method to perform the 10 seconds routine.
if(readsec==10)
portb=1;
else
portb=0;
like this.
