Hi april, What wattage are the soldering irons? I used that method to replace a burnt agp slot on a computer motherboard : I broke off the plastic housing and then un-soldered the metal contacts one by one.
Do you have a "solder sucker", a hand held, spring loaded de-soldering pump ?
Thanks for your offer of help with spares. I have attached a picture of the modification I did to get the tv in question working. Surface mounted components are not available here so I made a small circuit board, mounted a through hole NCP1207 on it and wired it on top of the power supply board.
Please expect to hear from me.
I am using a Latronics 800w sine wave inverter made in Australia and it is solid and reliable.
Timescope
Timescope
