4069 as variable resistor
prprog
I try to search the web on this (read about it a long time ago)->used a 4069 hex inverter as a variable resistor. Any idea on how this can be done?
I don't see how it can be done, it's a buffer not a variable resistor.
I've seem them used as a VCO and an analog amplifier, but never as a resistor. What are you trying to build?
A long time ago the CD4007 was shown how it could be used as a variable resistor.
Switched capacitor filter?
Let me guess, I assuem it involved operating the MOSFETs in the ohmic region.
The neat thing about the CD4007 is that you have semi independent access to the individual MosFets in the IC and can operate both the P and N channel devices as open drain. Maybe prprog should use this IC or a discreet MosFet for his "voltage controlled resistor".
He could also use a 4066 analog switch and has 4 bits to change resistor values.
Hans
