3 Phase current with Transfos and stuff
By Transfos I assume you mean Transformers? What exactly are you asking? Three phase power distribution comes in a few "flavors" for example a Y (WYE) configuration or a Δ Delta configuration. Which did you have in mind?
As to a "good website" this link is to a .pdf that is aimed at the trades and is a good read. I am sure a Google of Three Phase Power or Current should bring up a wealth of information.
Ron
Thank you, your PDF will do the trick :)
Yes transfo (transformers) with delta-delta-, wye-wye, delta-wye, wye-delta configuration with delta ou wye loads.
