24v supply from battery pack. Need direction
mrnight01
Wow. Glad I found this site.
I have been out of electronics for 20 years or so. Things have changed a bit. I have forgotten a LOT. I am trying to get back into it as a hobby.
I am looking to make a battery pack that will vary between 21 and 29 volts, lithium. I would like to have a 24v output at 4a max.
Can I get some suggestions on what to start reading on? Or if it is even possible.
I am wanting to make a battery backup for a CPAP machine. I do not know what the voltage tolerance is on the machine.
Thanks..
(I reread my post and see where the confusion is. I am looking to regulate the voltage at a constant 24V dc.)
That is basically what I am putting together. I am using 18650 2000mah cells in a 7S8p configuration.
Model: LGEAMF11865 (ICR18650MF1)
Capacity: 2150mAh Rated
Voltage: 3.65V Nominal
Charging: 4.20V Maximum
1075mA Standard
2150mA Maximum
Discharging: 2.75V Cutoff
430mA Standard
10000mA Maximum
The load is labeled 24V 3.75A. The goal is 6-8 hours.
For some reason in my notes, I have a 7s2p pack as 4.4Ah and 111Wh.? The load is 76.5W ( (24*3.75) *.85). That would give 4.9 hrs. I think my figuring is wrong.
I may be over thinking things a bit and am worried that the CPAP can not run in 21-29V range.
How about making the pack four cell series, so around 12 - 16V working range, then using an off-the-shelf car laptop PSU to give the stabilised 24V output?
eg. one of these, or similar:
That's rated 120W so should be good for up to 5A as 24V, and it doubles as a mains power unit.
Car batteries are rated 11V when near flat to 15V on charge so a very similar range.
A version for 24V, or 12 / 24V universal input for cars & trucks would be even better but I've not found one so far.
(Such things do exist, I have a Lind 12 - 24V input one with 16V out for my Toughbooks).
The original pack was going to be 7S8p = 56 cells. That could equally be arranged as 4S14P with the same overall capacity.
Are you sure about the CPAP voltage? Mine and every one I've see are 12 volts.
I just found out on an apnea board that my machines use a reference voltage on their power plug. A straight 24v will not work. They are working on what I was wanting to do.
I was just hoping to get around using a wall wart to save some power.
Thanks.
The new Resmed machines switched to 24v. My old one used 12v. That made life easier but there is no money in it I guess....lol
I would suggest to buy a couple of 18V lithium packs meant for power tools, recharge them one by one in the charger meant for that tool, Find a couple of carrier connectors from junky tools at the pawn shop, and connect them in series at the CPAP.
In other words, use commercially available assemblies/packs.
