24V input to 24Voutput with 4-20mA
harrisonic
hello everyone!!
I just need a help on how can i make a 24 volts input source to 24 volts output with 4-20mA output.
..do I need to use a current loop primer?..
..unfortunately I'm not familiar with this..
I am gladly appreciate if someone can provide me a diagram..
thank you for the help..and more power.
I have no idea what a "current loop primer" is.
I could take a guess, but I have never heared the expression before.
What you need is a constant current generator of some sort.
Have a look at the attachment, just using two components, an LM317 voltage regulator and a variable resistor, you can make a nice little constant current generator.
To calculate the required resistance:
resistance = 1.25/current
Note that the output voltage will not be fixed at 24v, but will vary depending on the load resistance and the current flowing.
Does that help?
Jimb
I think the o/p wants something that will generate a 4-20ma signal such as used in industrial instrumentation.
You can do it with an op-amp, a volatge to current source circuit, with an offset input to set the zero at 4mA.
Heres an interesting link, with a test circuit for 4-20ma.
Long time I do not run across of such a clear explanation. Good.
