18LF2520 Crystal
camerart
Looking at the Data sheet for 18LF2520 PIC, it shows the highest speed crystal as 25MHz. I only have 32MHz, will they work ok?
Camerart.
I don't think so.... The max speed of this is 40Mhz but 10Mhz (4x) PLL.. So 32Mhz should only be an 8 Mhz crystal with the PLL..
I don't think a 32Mhz crystal would stabilize.... This is just in my opinion...
Hi R,
Ok, that's a shame. Anyone want 20x32MHz crystals? :)
C.
On re-reading the Data sheet, I think the PIC will work without a crystal.
I've tried setting OSCCON and PLL, but 18LF2520 does appear to be running correctly. Can anyone supple the OSCCON and PLL settings for 8MHz and X4 please.
C
You need to set OSCCON to 0x70 ( 8Mhz) and set the PLL bit in the config register.. I think there is a software bit aswell.
So config FOSC= INTIO2 and PLLEN = 1
Then OSCON = 0x70
Then OSCTUNE bit 6 needs to be 1.
Hi I,
I think I've got it set correctly, but it's too fast.
Can you try it in the simulator please. The SIM is a bit faster than the PCB, but still shows too fast.
There is no INTIO1 and 2 option. I used this:
Thanks, C.
  • 18LF2520 8MHz 2XPIC SERVO X6 010918 0830.bas
Hi I,
Thanks, C.
What is too fast?
Waitus 1000?
Define clock_frequency 8 -> change to 32
