I need to provide a cable tester with a 10VAC power supply. The input to this tester is a three pin plug with the center pin being neutral. The other pins are supposed to be 10VAC. My question is: is this 10VAC measured 10VAC from pins 1 & 3, or 5VAC measured from center to pin 1 and center to pin 3? The neutral has to come from the center tap on the transformer right? It can't come from anywhere else can it? The actual picture of this wall wart says 10VAC, but that is all. It has to be a center tap 0-5 on each side right? Or is there some other way this could be wired?
Russ
Russ
