100uF bypass Caps?
For The Popcorn
Most Helpful Member
I am having a heck of a time getting I2C working with MCP23017 port expander. I've checked the connections, verified the values of my pullup resistors (4.7k) and so on but code that has worked before isn't working for me on these new boards.
While looking at the board, I noticed my 0805 100nF bypass caps seem unusually thick – they're about as thick as they are wide. I don't have a capacitance meter, but my "component tester" says they are around 130uF, not 100nF. It's possible that my assembler screwed these up.
It doesn't seem like this should matter much, but there are about 10 of them on the board. Do you think this would make a difference? Yes, reaching for straws at the moment....
The caps to the right of the crystal are 22pF, and I expect 100nF (C53 & C2) should be about the same thickness.
Ok, the thickness does check out per the datasheet for 100nF caps.
100 µF capacitors in 0805 are pushing the limits of what can be achieved and they don't work nearly as well as physically larger 100 µF capacitors
I suspect that the 100 µF capacitors have a higher impedance than the 100 nF capacitors at the frequencies that you need them to work at, so you are not decoupling properly.
Can you replace the capacitors or just solder some 100 nF one on top to see if it makes a difference?
After looking at the datasheet, the square profile is the right aspect ratio for 100nF in this line of caps – usually they seem to be thinner.
I don't have a lot of faith in the readings of the component tester when hand-holding the leads. I suppose measuring in circuit, you're also measuring the total of all the caps in parallel. If I don't find another explanation for my I2C issues, I'll desolder one of the caps to be sure.
As he's measuring the total capacitance on the rail, 130uF sounds pretty spot on - you would expect an electrolytic or two on the rail, as well as a number of 100nF.
I don't quite see why the OP expects 0.1uF capacitors to be the same thickness as 22pF ones?, particularly as they are over 4,500 times larger in value. Does he expect a 4,500 gallon oil tank to be the same size as a gallon can? :D
Once again, your experiences and mine may differ. Considerably. I have noticed over the years that fairly large 0805 caps, say 10uF, have a square profile. The stand noticeably taller on a PCB than 100nF or 22pF caps. While these smaller caps may not be the same thickness, in MY experience, they usually do not appear to be square.
Your insulting remark is appreciated.
One of my boards has three of these on board. Virtually every one requires my attention as Pin 1 on mine has a via too close to the pin. The solder flows through the via and leaves the pin just touching so I have to manually top this solder joint.. The pins on those of mine were ever so slightly raised up.
Once done they worked a treat. If they worked before, then this sort of thing should be looked into.
BTW, I don't think its the cap either. I once put 1uf by accident and they still worked.. It doesn't impede the signals only the power.
I've used the MCP23017s on other boards without problems. The problem is on a new board I'm trying to bring up. Which makes it especially frustrating.
Is there just the one? I have another board that has one.. BUT a 3.3v PSU. the PSU had awful noise and the chip would not work.. Again like you the previous boards were fine.. There was an issue with the 3v3 rail.. The MCU was fine and as the LCD was sitting on 5v, that also was fine, but the SPI was up and down like a fart on the wind.. I was getting a 20mV noise, I has to really zoom in on the scope to see it. I banged anoth 10uf to "kinda" sort it.. The problem was with another SPI device on the system, but the expander looked like the issue. I know you said yours is I2C but same can happen.. Again the original board was fine..
Do you have a logic analyzer or a scope with LA capabilities?
If not borrow one. I once had a stubborn timing issue which would have been impossible to figure out without a LA.
I have never been able to fault-find I²C without an oscilloscope or logic analyser.
Often, on I²C, the low voltage levels are slightly different for the master and slave, which can help when using an oscilloscope.
The different levels can be seen in the bit I've circled.
You can put a small resistor in series with either the master or slave data line to induce a similar effect if the two data connections are too similar to see the difference.
Don't know about 0805s but 1uF 1206 MLCC capacitors are definitely taller than capacitors with values of 100nF or less in my experience. They have the same footprint but are much chunkier.
new board isn't this a new uC
Yeah, new board with a new micro. But I'm getting nowhere so I verified all connections and parts values yesterday and found no problems.
My test mode with old code on the micro I've been using may be a problem too. The new micro is a 40 pin DIP in a socket. My old code is on a 28 pin DIP. Here's what I tried, and maybe it's not a valid way to test.
1. Erase the 40 pin micro. Leave it in the socket.
2. Connect the board with the 28 pin micro I2C connections to the 40 pin board. There aren't any I2C devices on the 28 pin board.
3. Attempt to address the 40 pin board I2C devices.
The code hangs when I try to read from the I2C devices.
My thought in doing this was the blank 40 pin micro's port pins would all be inputs, and have no impact on the circuit. Bad assumption?
Making progress finally. With an external board with an 18F25k22, I am able to see the I2C devices. Yay. The other board I used for testing is somewhat suspect.
Now I have some faith in the new board! Whew.
Will the Swordfish I2CX module work with the k series parts? Formating is slightly different – I'd like to do some testing with the k22 part before switching to the Q83.
