0.5Watt LED Driver
yngndrw
Most high power LEDs are run off constant current drivers, but is this really needed ?
Can a 0.5Watt LED be run using a normal safety resistor as long as the resistor is rated high enough and the LED has a heatsink ?
Are the only reasons these LEDs are run off constant current drivers because of varying input voltages and for efficiency ?
Thanks.
LEDs are rated for current. Their forward voltage is a wide range of voltages so you must measure the forward voltage to calculate a current-limiting resistor for it.
Well the LED spec says:
Forward Voltage : 3.0v-4.0v
Forward Current : 150mA
Should I assume the lower or upper end of the forward voltage scale ?
How can you assume a voltage? Assume the lowest voltage then most LEDs will be too dim but none will burn out.
You either measure the forward voltage and calculate a current-limiting resistor for an LED or you make a constant current source for it.
Assuming the lower forward voltage will result in a conservative (higher) estimate for the resistor. However, if your supply voltage is not close to 3V (like >6 V), using either value is not going to make much of a difference.
That said, it wouldn't hurt to actually measure it.
Okay then I'll measure it, is a constant current source required to measure the forward voltage drop or can I just use a safety resistor which is in a reasonable range ? It's a little embarrassing to have to ask such questions about an LED, but I never really looked into them that much. :o
Thank you for your help.
Use a proper current source rather than a simple series resistor, then you won't have to worry about the forward voltage providing your regulator can provide the voltage at the lowest supply voltage.
True, I was thinking of just testing how bright it was untill I can get a proper regulator setup, but you're right I may aswell just get a regulator sorted out now - It would be a different brightness anyway.
Thanks everyone.
