    Dismiss Notice
Zener diode datasheet, how does company choose test current?
Discussion in 'Homework Help' started by wiwa_ze, Aug 15, 2010.
  1. wiwa_ze
    wiwa_ze New Member
    Aug 15, 2010
    3
    0
    BKK, Thailand
    I've seen many datasheet about zener diode for regulator voltage.
    And zener voltage depends on test current, right?
    So I want to know how to manufacturing company choose test current?
  2. Dragon Tamer
    Dragon Tamer Member
    Oct 8, 2009
    848
    5
    Landenberg, Pennsylvania USA
    The voltage of a zener diode is constant, it won't change if the current changes. The manufacturer does not "choose" the current of a zener, it is measured as the maximum amount of current that the zener will allow to flow through itself without being damaged.
  3. wiwa_ze
    wiwa_ze New Member
    Aug 15, 2010
    3
    0
    BKK, Thailand
    Thanks Mr. Dragon, for your answer.
    But what is the origination of Izt and Vzt??
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Jony130
    Jony130 Active Member
    Feb 1, 2009
    292
    28
    Well, almost all manufacturers use 5mA as a test current.
    Why it's 5mA I don't now. Maybe its has something to do with "knee" of a Zener diode.
    And to make sure that the Zener diode will produce the Zener voltage the current must be at least equal to test current.
    http://www.electro-tech-online.com/threads/zener-diode-test-current-izt-help.39227/#post311687
  6. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,593
    477
    L.A., USA Zulu -8
    The manufacturers choose a convenient current that's well above the "knee" of the Zener, so the test is well into the flat portion of the zener voltage versus current region. Some small zeners have a low current knee, so they are tested at a lower current, whereas high power zeners are generally tested at a higher current.
  7. crutschow
    Mar 14, 2008
    10,593
    477
    L.A., USA Zulu -8
    That is not correct. They test at a much lower current, then that.
  8. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,234
    641
    Derbyshire, UK
    Sorry, but it's a LONG way from constant - the datasheet will usually even provide a graph showing the voltage changes with current.
  9. wiwa_ze
    wiwa_ze New Member
    Aug 15, 2010
    3
    0
    BKK, Thailand
    Thank you very much.
    It's cleared.
Share This Page
